V8 or better crawl ratio? - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 20th, 2007, 09:00 PM   #21
Novocaine
Jeeper
Novocaine's Avatar
This past winter i swapped in a 2006 all aluminum 5.3L w/ the 4L60E. The only factory gauge that is not working is the tach. I replaced the 4.0L, AX-15. Tons of power turning 36" Iroks now. Let me know if you have any questions on the swap. Rick
Novocaine is offline   Reply With Quote
Old August 9th, 2007, 09:03 PM   #22
jeepfreak81
81 inches of fun
jeepfreak81's Avatar
Originally Posted by 99grandtj View Post
I guess I am going to go with a Chevy motor... they are very reliable and I can get parts anywhere if I break it on the trail, it makes the most sense in the long run... not to mention cheap to build.
Bout time you saw the light.
Old August 9th, 2007, 09:18 PM   #23
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
Falsifying a quote is wrong jerk
FYI it will be a all aluminum engine, but it ain't no gm product :tonka:
Old August 10th, 2007, 01:22 AM   #24
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
I am geared 84:1 in low range, and I think it fits the 4.0 perfectly. I have never really wanted more power for wheeling... maybe to beat on around town.
JcrOffroad
Zoom Zoom!
Old August 10th, 2007, 02:20 AM   #25
boggin-machine
boggin-machine's Avatar
i know you want to stay away from gm about what about a small block with a sm455 with granny gear and still cruise good on the road??
Old August 10th, 2007, 10:13 AM   #26
Jeepaholic
Jeepaholic's Avatar
Will never be a small block
It will be an auto, to much sand and mud for a manual. Besides a atlas 4 speed is cooler anyway.
Old August 10th, 2007, 11:25 AM   #27
Blackjackbender
dana 300/231 crawler box.
Old August 10th, 2007, 02:58 PM   #28
PavementPounder
PavementPounder's Avatar
Injected Magnum 360, the Dodge NV4500 Rubicon 1 is selling, NV241OR.
Old August 10th, 2007, 03:06 PM   #29
Jeepaholic
Jeepaholic's Avatar
If it was an eariler model tj, then that is what I would do. But is gonna be a newer model and the electronics won't like each other.
V10, 48re, atlas 4.3 most likely
Old August 10th, 2007, 03:11 PM   #30
PavementPounder
Maybe you should just start over with a shortbed V10 Ram and truggy it.
Old August 10th, 2007, 03:19 PM   #31
Jeepaholic
Jeepaholic's Avatar
Close, but I want a different v10, and the one I need only comes in a crew cab.
Old August 10th, 2007, 03:26 PM   #32
liv2mx
i like jungle gym's.
liv2mx's Avatar
get rid of your rear end go with a 14 bolt and run 5.38. i had to ditch the 70 because of the delay in gearing. stroke your 4.0 and put a supercharger on it if you want to keep your current setup. wheeled with a guy that had a 4.0 stroker w a supercharger and that thing had some serious nuts.
Old August 10th, 2007, 03:31 PM   #33
Jeepaholic
Jeepaholic's Avatar
I am starting over with a unlimited, I need more room for kids/friends without a ride :tonka: I am doing this one the way I want it from the begining. I have everything worked out except a few small details
Old August 12th, 2007, 01:21 PM   #34
Cartman
Can't lose with 42s
Cartman's Avatar
Dodge Route
Magnum 360, NV4500, NP241HD out of a cummins....
Or go the Ford Route
347 stroker or stroker 351W, T18 or ZF5 for the OD, BW1350/1356 crawl box....hmmmmm damn good crawl ratio, and some HP for tire cleanage in the mud.
Chevy route..
TPI 350 stroked to 383, NV4500, NP203/205 doubler
Jeep route
Stroke your 4.0 to a 4.6 and runwhatcha brung and hope the auto trans lives and that the 75HP you gained is really enuf...
Nevermind, I saw you want an auto...that blew my plans all to hell...can't expect to get too crazy with crawl ratios unless you have an atlas or a doubler since you won't take advantage of a manual with a granny 1st
Cartman is offline   Reply With Quote
Old August 12th, 2007, 04:40 PM   #35
Jeepaholic
Jeepaholic's Avatar
It would be a 403? magnum
or 408W
or a LS1
Motor will make up for gearing.
Old August 12th, 2007, 07:52 PM   #36
Cartman
Can't lose with 42s
Cartman's Avatar
Won't make up for much if you need to crawl though....
not many rocks here in michigan though
whatever you do, post it in the rig builds. Sounds like fun!
Old August 12th, 2007, 08:04 PM   #37
Jeepaholic
Jeepaholic's Avatar
It will be in there in a few months. Picked up the first piece toady, let the build begin
Page generated in 0.38449 seconds with 74 queries
