throttle body injection issues! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 20th, 2007, 12:53 AM   #1
nicktofferi
Send a message via AIM to nicktofferi
Default throttle body injection issues!
well i have a chevy 350 small block in my jeep and have been working on putting on a gm tbi unit and harness. i have it running with the computer running the timing. the timing is set to zero. i have all sensors hooked up, knock,temp,o2.... everything: the jeep runs but it runs at about 80%. when in park and give it gas it runs pretty good. when you get going down the road and give it gas it just kind of misses and spits and sputters while i am feathering the gas. when u slow down to a stop the thing comes down to a real low idle where it seems like it might stall then it "adjusts itself" and the idles seems to go up. i installed a knock sensor this weekend because some one advised i needed one and when i first started it it ran amazing for the first 30 sec. once it warmed up it ran like it always did. it seams to always run good at the beginning? ?????
things i might think could be an issue:
1. where my exhaust meets the header there is a slight exhaust leak because of a blown gasket. it is just above the o2 sensor in the exhaust.
2. the header bolts could be a little loose. could this be giving the knock sensor a false knock?
3. the only wire i dont have hooked up that might be needed is the one that tells the computer what gear it is in
any info where to go form here would be great.
thanks nick
nicktofferi is offline   Reply With Quote
Old July 20th, 2007, 02:05 PM   #2
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
I vote fuel pressure. Did you run a return line back to the tank? What fuel pump did you use?
Old July 20th, 2007, 02:58 PM   #3
x2
Old July 20th, 2007, 03:06 PM   #4
TopHeavy
Yikes!
TopHeavy's Avatar
This could cause the engine to think it is running lean.
Most likely not.
I have no clue where to hook that up
thanks nick
Good Luck.
Buy My CJ7
TopHeavy is offline   Reply With Quote
Old July 20th, 2007, 03:31 PM   #5
nicktofferi
i bought a fuel pump at auto zone. i told them i had a 88 full size pickup and it is located in tank. yes i do have a returnline.
Old July 20th, 2007, 03:46 PM   #6
clarkstoncracker
lol
clarkstoncracker's Avatar
Does it smell like its running extremely rich? Try unplugging your TPS and see if that affects the idle.
Old July 20th, 2007, 06:09 PM   #7
Cartman
Can't lose with 42s
Cartman's Avatar
So I'm assuming it has not set a trouble code? It just runs terrible?
Cartman is offline   Reply With Quote
Old July 21st, 2007, 11:38 AM   #8
nicktofferi
going to trouble shoot the codes next week.
Old February 18th, 2008, 04:56 PM   #9
nicktofferi
well have been tinkering with for a while now..... i have ran the trouble codes and it came up with high voltage tps sensor. changed the tps this summer and it fixed it for about 5 to 10 minutes but then started to run bad again. then i changed the pigtail and didn't help. any ideas? thinking my next step is to have the computer reprogrammed. thanks nick
Old February 18th, 2008, 05:19 PM   #10
Bones
Bones's Avatar
IAC isn't adjusted right or is malfuntioning
or fuel pressure
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old February 18th, 2008, 05:47 PM   #11
chevotass
chevotass's Avatar
get a holley blue fuel pump. i put a 87 chevy throttle body setup on my motor and had the same problem. i bought an autozone pump and it would idle fine. but once its under a load it sucked. bought a holley blue and have had nothing but great experience with it.
Old June 28th, 2008, 01:56 PM   #12
nicktofferi
Fuel pressure is running at just above 11 psi......I have read that it is standard to be running around 11-13. Then i will read posts about needing more than that. Should i take the fuel pump out and by a holley?
Page generated in 0.34689 seconds with 59 queries
