22r to re swap - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 19th, 2007, 06:01 PM   #1
88yj
collecting parts
88yj's Avatar
Send a message via AIM to 88yj
Default 22r to re swap
In theory I have everything I need to complete this swap except the fuel pump. I'm wondering if anyone on the board has tried to swap a truck to EFI. I've got the complete wiring harness, computer and all that. I even have the efi manifolds. I imagine this will take a while to do since it involves removing all the wiring in the dash and under the hood and then using the new harness.
If you've done this swap, are there any little things I need to remember before starting it? Will I need new fuel lines? What about pump location? does it need to be in the tank, in line or doesn't it make a difference?
Thanks.
88yj is offline   Reply With Quote
Old July 19th, 2007, 09:31 PM   #2
Best is in the tank, thats where the stock pump is.
Mine was carbed at first, but since I swapped a body on from an EFI truck, I got the wiring that way. Later when I swapped in the EFI motor, it just plugged in and went.
Old July 20th, 2007, 08:48 AM   #3
88yj
collecting parts
88yj's Avatar
Can I put an EFI pump in a tank from a carbed truck, or should I just switch to a fuel cell?
Old July 20th, 2007, 10:28 PM   #4
skife
skife's Avatar
you should do a propane swap.
Old July 21st, 2007, 09:55 PM   #5
88yj
collecting parts
88yj's Avatar
That does me no good if i want to drive any distance on the street.
Old July 24th, 2007, 11:46 AM   #6
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
what year 22r is it?
If it is pre 84.5 the manifold pattern is not correct and you will have to use a different head......you will either need one from an 83 or 84 celica 22re or the aftermarket one lc engineering sells.
I went through this whole ordeal......it was not fun.
Old July 24th, 2007, 12:00 PM   #7
88yj
collecting parts
88yj's Avatar
It's an 85.
I don't expect it to be fun, but I'm pretty much forced to do it to get the best in crawling and street driving.
Old July 24th, 2007, 05:11 PM   #8
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
you should be all set then.......It is not that bad just kinda time consumeing
Old July 24th, 2007, 06:13 PM   #9
Not quite.. the mounting bosses showed up on the 1983 heads, but 3 holes weren't always tapped until late 83/early 84.
My 83 had the flat mounting bosses, but not all of the holes drilled. You can just drill and tap, if necessary. But sounds like they are all there.
Old July 24th, 2007, 09:11 PM   #10
88yj
collecting parts
88yj's Avatar
I may pick up a running 22re for the swap and rebuild my 22r over the winter. My wrist pin rattle is getting kinda bad and I don't want to waste all that time swapping stuff to blow the engine a week later.
Old July 25th, 2007, 09:34 AM   #11
Rattler
Home Sweet Homicide
Rattler's Avatar
I was surprised at how long my wristpin lasted. She was a noisey one too. Roadhouse can vouche for it. It never did let go as long as I owned the truck too.
Old July 25th, 2007, 09:52 AM   #12
88yj
collecting parts
88yj's Avatar
Well, my carb sucks and I can't idle most of the time. I have to attack hills with full-throttle. This would just fix most of my problems and potentially create a huge new one.
Old July 26th, 2007, 06:16 PM   #13
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Ok.......well mine must have been an early 83 cause everything was off. I simply used the head from a Celica and all was good
Page generated in 0.29290 seconds with 62 queries
