ALso on my bronco ~ - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 20th, 2006, 11:18 AM   #1
equineolove
GeTtIE Up!!
Default ALso on my bronco ~
my emergency break light comes on while i am driving!! there after a Rear Antilock light comes on and they stay on. ummm if i slam on my breaks the go off, but come back shortly after. it doesn't run bad or nothing when they are on besides my jerking! > >> bus so ummm is that just a faulty commection? it is awful he is falling apart. help!!
equineolove is offline   Reply With Quote
Old February 20th, 2006, 11:51 AM   #2
Lothos
KD8GKB
Lothos's Avatar
It means the spring/cable assembly for the e-brake is probably shot. The sensor is behind the dash I believe triggered by the pedal movement. So, with no spring to retain the brake pedal the pedal falls slightly for the light to come on. It's not hard to replace, but the back half requires dismantling the left rear brake drum to get at the cable end.
Old February 20th, 2006, 12:04 PM   #3
Those symptoms can also be caused by low brake fluid. Acceleration sloshes fluid away from the switch, braking sloshes it back.
I've seen this on sevreal vehicles before, but know nothing specific about broncos..
Old February 20th, 2006, 12:06 PM   #4
Lothos
KD8GKB
Lothos's Avatar
The E-brake is a cable driven system though unaffected by the fluid in the normal braking system. The only way fluid would cause the light to come on would be loss of pressure in the rear drum cylinder and the pads actually moving as a result to move the cable. It's very difficult for this to happen though really since the E-brake arm in the drum kicks the pads out when pulled and the spring on the outside of the drum pulls that level back out when released.
Old February 20th, 2006, 12:20 PM   #5
Like I said, I have no specific bronco info. Don't know if its a ebrake speicfic light.
I design instrument clusters and used to design brake systems, so my info in generic. Most vehicle don't have a 'ebrake' light. They have a 'brake' like, which is a combination light which usually lights with the ebrake is on, and also when there is a loss of fluid in the master cylinder, or other system fault.
First step in diagnosing a 'brake' light should always be to check the fluid.
Old February 20th, 2006, 12:26 PM   #6
equineolove
GeTtIE Up!!
thanks i will do that > i did pop a break line just back in jan so maybe it is low now that it is all restocked in there....i wish i could have a vehicle that didn't always break...oh well i still love him.
Old February 20th, 2006, 03:47 PM   #7
Icebreaker88
Icebreaker88's Avatar
To eliminate the ebake as a cause there should be a wire going to the e-bake assembly under the dash at the e-brk pedal. . When you press the e-brake it just grounds the wire. You can unplug that wire to see if you e-brake switch is bad. if the light goes out it is in the e-brake switch if not then its somewhere else in the brake system.
[QUOTE=TurdBronco;1095911]I don't usually race cause it is still a focus.[/QUOTE]
Icebreaker88 is offline   Reply With Quote
Old February 20th, 2006, 04:08 PM   #8
equineolove
GeTtIE Up!!
thanks
Page generated in 0.23633 seconds with 47 queries
