Wiring problem with my tail light... - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 18th, 2007, 11:05 AM   #1
halycon
^^ NOOOOB
halycon's Avatar
Send a message via AIM to halycon
Default Wiring problem with my tail light...
Originally Posted by MuddyPaws View Post
hahaha...
Glad I can help. I love wire problems.
OK Muddy, I got one for ya too!
I'm having a left tail light issue in my '99 Ram 1500 Sport- one bulb turns on in reverse, but not the other (the one with the shorter wires).
The purple wire coming from the front of the truck that hooks into the trailer connector had carbon or something built up inside when I stripped it (even though when scraped off, the wires looked fine), but the wire was fine on the other side of the connector (which goes to the bulb). The purple wire was NOT the one connected to the bad terminal.
Thinking it was just a bad connection, I cut the 2 sides of the connection out and then spliced in a new connection, so everything is connected properly. My tail light now turns on, but in reverse only 1 of the bulbs lights when both should be. If the wire looks charred like that will it still conduct properly if scraped clean on the contacts, or is the wire useless? I forgot if the purple wire is one that goes into the bulb that won't light, but I'll check when I get home.
Any input in the mean time would be greatly appreciated!
halycon is offline   Reply With Quote
Old July 18th, 2007, 04:25 PM   #2
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
well if it helps to know any chared wire has lost its ability to carry current. if you think about it the elctrons travel on the surface of the wire. if its chared then they are blocked by carbon. the gauge of the wire is there to reinforce the wire while it builds up and throws off heat. so clean up the carbon and if its chared there, its most likley chared under the ground side.
Yetti
Old July 19th, 2007, 07:43 AM   #3
halycon
^^ NOOOOB
halycon's Avatar
Yeah, I suppose that makes sense. Damn, time to start ripping shit apart and finding how far up the bad wire goes.
Old July 19th, 2007, 06:48 PM   #4
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
I'm thinking same thing. That wire is just bad going up there.
Quick test....hook a jumper wire from the working light all the way over to the other reverse light. See if it lights then.
Page generated in 0.28769 seconds with 35 queries
