Axles (Corp 14 R & 10 F? and D 30 F, 35 R & 44 R) - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 17th, 2007, 10:59 AM   #1
magna-007
magna-007's Avatar
Default Axles (Corp 14 R & 10 F? and D 30 F, 35 R & 44 R)
I have a Corp 14 rear and Corp 12 front, 8 lug, heavy 3/4 ton axles. Matching gear set. Think 4.10s. Not sure at moment if locked or open. Can check if interested. Both came out of mid 70s Chevy heavy 3/4 Ton. $200 OBO for both.
Also have a Dana 44 rear out of a mid 80s Jeep Wagoner. Was told 3.55 gears. $100 OBO
Lastly. If anyone is seriously interested!!! I will have a set of Wrangler axles available this winter. Front is the Dana 30 and rear is the Dana 35. Both matching 4.56 gears and both locked. Plan to upgrade to D44 front and 9 inch rear. Axles are still under Jeep and in great working condition. Lots $$$ invested. Would like to get $600 for the pair.
Would consider trades for a (ready to bolt in) locked 4.56 Ford 9 inch and locker and (4.56) gears for a front D44 that i have. Would also consider 4.10 gears for both.
All axles are at my house in the west end of the Lansing area close to Portland. (most don't know Portland so I say Lansing area) Can email me at teachoutc@hotmail.com
Wanted to add pics of axles. The 14 and 10 bolt are 4.10 gears. The 14 is also a possible Detroit lock.
ID:	12247   Click image for larger version
ID:	12248   Click image for larger version
ID:	12249   Click image for larger version
ID:	12250   Click image for larger version
Last edited by magna-007; July 19th, 2007 at 10:17 AM. Reason: add more detail to title
magna-007 is offline   Reply With Quote
Old July 17th, 2007, 11:13 AM   #2
1x1_Speed_Craig
Simplify...
1x1_Speed_Craig's Avatar
You may want to pull the cover and verify the gearing in this axle yourself. If it's a mid-'80s, they were usually 2.73 or 3.31 from the factory.
Good luck with the sales!
Craig
Old July 17th, 2007, 11:24 AM   #3
PavementPounder
PavementPounder's Avatar
Front 12-bolt? I thought they were rear-only. Sure its not a 10-bolt or a D44?
Old July 17th, 2007, 11:31 AM   #4
magna-007
magna-007's Avatar
Pretty sure it was a 12 bolt pan, will double check. They were both Corps for sure though and matched set. Thanks
Old July 17th, 2007, 11:41 AM   #5
magna-007
magna-007's Avatar
Craig
Will do, thanks for the advice. Picked up the set for the front 44. Guy thought they were 3.55, but I didnt really care either way as planned to change out.
Old July 17th, 2007, 11:43 AM   #6
PavementPounder
Look at these links for pics and specs:
http://www.usgear.com/tl/dana1.htm
http://www.usgear.com/tl/gm1.htm
http://www.usgear.com/tl/gm2.htm
http://www.usgear.com/tl/gm3.htm
Old July 17th, 2007, 11:53 AM   #7
Blazin79
Blazin79's Avatar
would like the 8 lug front axle only... let me know how much
Blazin79 is offline   Reply With Quote
Old July 17th, 2007, 02:16 PM   #8
magna-007
magna-007's Avatar
Hows a $100 sound.
Old July 17th, 2007, 04:47 PM   #9
Blazin79
Blazin79's Avatar
Hows a $100 sound.
sound good but rather u find out if it s 4.10 for sure
Old July 17th, 2007, 04:55 PM   #10
natureboynate47
natureboynate47's Avatar
how much for the 14 bolt
natureboynate47 is offline   Reply With Quote
Old July 17th, 2007, 05:38 PM   #11
OlllllllO
OlllllllO's Avatar
what year wrangler are the D30 and D35 from?
OlllllllO is offline   Reply With Quote
Old July 18th, 2007, 08:54 AM   #12
magna-007
magna-007's Avatar
1995, both still under Jeep for the moment. Plan to do the swap this winter.
Old July 18th, 2007, 08:55 AM   #13
magna-007
magna-007's Avatar
Hows a 100 sound?
Old July 18th, 2007, 08:56 AM   #14
magna-007
magna-007's Avatar
Will do. Will take some pics tonight also.
Old July 18th, 2007, 09:32 AM   #15
natureboynate47
can you double check the ratio on the 14bolt too please. is it a full floater?
Old July 18th, 2007, 10:27 AM   #16
magna-007
magna-007's Avatar
Will do on the ratio. Yes, its a floater. Its the larger 14 with the 10.5 ring.
Old July 18th, 2007, 03:47 PM   #17
Blazin79
Blazin79's Avatar
more llikely i ll take first dib on the front axle once u find out the ratio ... thanks
Old July 19th, 2007, 10:20 AM   #18
magna-007
magna-007's Avatar
Its definately 4.10s See above pics just added. Your right it was a 10 bolt. Not sure what i was thinkin when i said 12.
Old July 19th, 2007, 10:27 AM   #19
magna-007
magna-007's Avatar
Craig
Its definitely a 3.54 ratio. Still has tag and gears calc to a 3.54 also. Odd ratio for sure. I will also have the gears out of the front D44 that will make match set if anyone interested. Plan to go 4.10 or 4.56 again.
Old July 19th, 2007, 10:46 AM   #20
PavementPounder
I'm rolling to Magna's in the next couple days with a utility trailer. If anyone wants an axle brought back to Oakland County for a few bucks, work it out with him and let me know.
Page generated in 0.54892 seconds with 84 queries
