anyone ever hot rod a ford 300-6 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 16th, 2007, 11:33 PM   #1
gofastbobby
The guy Dale doesn't know
gofastbobby's Avatar
Default anyone ever hot rod a ford 300-6
i am thinking of putting some money into a small cam, intake, header and holley 4bbl for my 300-6. anyone with any expirience on this? thoughts?
i am mainly concerned about reliability. thats why i went with a 300 in the first place.
gofastbobby is offline   Reply With Quote
Old July 16th, 2007, 11:37 PM   #2
PavementPounder
PavementPounder's Avatar
Read up:
http://www.cliffordperformance.net/M...gory_Code=F300
Old July 16th, 2007, 11:48 PM   #3
gofastbobby
exactly what i was thinking, except probably an offy dual plane intake.
Old July 17th, 2007, 12:28 AM   #4
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Done it LONG ago on a f150...think that was my 78...maybe 79. Made a good bit of difference. All I did was cam, better pistons, 4bbl and intake....little port matching, nothing hard core. It was an Offy intake....back then it was the ONLY option and Jc Whitney was about the only place you could get it.
Revved a bit higher and had quite a bit more pull in the higher RPM range. The old 300's didn't have much over 3000rpm.
Old July 17th, 2007, 01:57 AM   #5
gofastbobby
i thought you might have something to say about this one. thanks.
Old July 17th, 2007, 02:05 AM   #6
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
You sayin i'm old and have done a bunch of stuff?
Old July 17th, 2007, 02:08 AM   #7
gofastbobby
no just uh....expirienced, yeah.
Old July 17th, 2007, 01:00 PM   #8
Cartman
Can't lose with 42s
Cartman's Avatar
I got one in my 83' bronco.. It's got chevy EFI, offenhauser single plane and dual outlet (efi) manifolds. It revs to 4800 (according to stock tach)
There is a video I posted on here awhile ago of me blowing out my front end with it...its rippin pretty good
check out www.fordsix.com for all of your performance needs....most runs run chevy rockers (1.6) and a cam....some have gone to great lengths and modified 351M pistons to work and there is even an aluminum head in the works...
edit:
heres the link
http://vids.myspace.com/index.cfm?fu...oid=2023022581
Cartman is offline   Reply With Quote
Old July 18th, 2007, 01:12 PM   #9
Westside Willy
Westside Willy's Avatar
Great engine, great choice for reliabilty. Make sure you use the steel crank gear / cast iron cam gear with the FINE teeth. These engines have great potential, they were just choked by the 1 bbl carb and later FI engines used the too small throttle body. The ports and valve are bigger and better than stock 302/351W, bigger bearings, etc.
Chucks Engine ( Westland 734-727-1760 ) used to have a bunch of forged steel cranks ( fully counterweighted, great flywheel effect, may not rev as fast though ), they have moved a couple times since I was there - give Ricky a call at the number above. Keep us updated on how it runs for you.
Westside Willy is offline   Reply With Quote
Old July 18th, 2007, 11:02 PM   #10
bj house
bj house's Avatar
fantastic motors for reliability had one in each of our stick shift vans (83 and 85 E150's).
Old July 18th, 2007, 11:21 PM   #11
Hacksaw
WWSD - What would stan do
Hacksaw's Avatar
edit:
heres the link
listen to this dood.
His shit RUNS.
Page generated in 0.24977 seconds with 56 queries
