long shot but need help on a 220 Bayou - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 14th, 2007, 10:56 AM   #1
cannaert
No more Jeep
cannaert's Avatar
Default long shot but need help on a 220 Bayou
I am looking for some one that knows any thing about Kawasaki stuff.
I brought a old Bayou 220 and was riding it around and it just shut off. Would not turn over. (Mind you all the ignition was cut out and a push button ignition put on it) Starter was clicking and that was it. Pulled the the starter out and it works fine.
i put it all together and now the start work but the gears that it engage into the starter gear now dont work.
I guess what I need is a wiring diagram or some help with this thing.
thank Chris
Old July 14th, 2007, 11:59 AM   #2
Big Daddy Rubicon
There watching me! (.)(.)
Big Daddy Rubicon's Avatar
Did you try to turn the engine over with a wrench? To check to see if the engine is froze up?
[QUOTE=a.j. hall;1528363]
[/QUOTE]
Old July 14th, 2007, 05:55 PM   #3
cannaert
No more Jeep
cannaert's Avatar
I did no prob. Top end was redone less than 6 months ago.
Old July 14th, 2007, 06:01 PM   #4
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
check out www.kawieriders.com theres a whole tech section there for you.
Yetti
Old July 16th, 2007, 11:50 AM   #5
junk90xj
ALLPRO AUTO
junk90xj's Avatar
check battery voltage.
http://www.apalansing.com/
Old July 16th, 2007, 08:05 PM   #6
Motor Slut
I put the Ick in Dick.
Motor Slut's Avatar
Starter works fine is not an accurate diagnosis...
The starter relies on 100% power to engage the starter bendix and have enough torque to turn the motor over. A 4 brush motor will still work on 2 brushes but won't have the speed or power to start the engine.
Check your battery under load as well. You might have a cell dead. It should hold 10v with the starter engaged.
Old August 7th, 2007, 07:32 PM   #7
bikerted86
Ive seen worn gears in the starter drive, It will let the starter spin but will not engage the motor.
bikerted86 is offline   Reply With Quote
Old August 8th, 2007, 02:49 PM   #8
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
The starter was replaced the same time as top end.
Old August 8th, 2007, 08:10 PM   #9
bikerted86
there should be a series of gears that go from the starter to the crank, If any are worn the starter my not engage. Also i would have to see yours but i saw a motorcycle do the same thing and it used a system kinda like a stud remover and one of the springs was weak.
Old November 8th, 2007, 05:00 PM   #10
slvrlake survivor
It Aint Cheap to Jeep.
slvrlake survivor's Avatar
thank Chris
i have a bayou and the exact same thing happened to me.. it was a long time ago.. i dont remember the exact problem but something about how there are 3 pins to the starter and they fell out/ stripped something like that
slvrlake survivor is offline   Reply With Quote
Page generated in 0.30400 seconds with 53 queries
