TJ Hitch Bolts - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 18th, 2006, 01:39 PM   #1
Saharaboy
Donate to Me
Saharaboy's Avatar
Send a message via AIM to Saharaboy
Default TJ Hitch Bolts
What size bolts and nuts do I need to mount a 2" reciever hitch onto my TJ?
Anyone know??
Saharaboy is offline   Reply With Quote
Old February 18th, 2006, 06:45 PM   #2
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
if I remember right there are 6 12mm bolts that hold it on. it may require rail plates also(they go inside the rail so it has bolts holes)
Yetti
Old February 18th, 2006, 07:00 PM   #3
Kawierider
Kawierider's Avatar
Depends on the brand.
i think its a combo of 3/8 bolts and 1/2 in bolts i am pretty sure 3 total to a side.
if you buy a new hitch it will be included. if not use what fits in the holes make sure to use grade 8 hardware though.
Old February 19th, 2006, 10:53 AM   #4
Saharaboy
Donate to Me
Saharaboy's Avatar
4 Bolts total
2 - 1/2"-13 x 1.75"
2- 7/16-14 x 1.5"
Drawtite says use grade 5....but I am using 8
Old February 19th, 2006, 11:45 AM   #5
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
Originally Posted by Saharaboy
4 Bolts total
2 - 1/2"-13 x 1.75"
2- 7/16-14 x 1.5"
Stick with the grade 5. They are case hardened (not fully hardened only the out side). It creats a bolt that is hard but not as brittle as a fully hardend grade 8. A grade 8 bolt is very hard but brittle and are more likely to shear than bend under extreme loads. Make sure you apply the proper torque to them. Click here if you don\\\\\\\\\\'t know the torque spec.
Old February 20th, 2006, 04:47 AM   #6
Ebs
A grade 5 bolt will still stretch and break before a grade 8 bolt by a large margin.
Page generated in 0.36797 seconds with 41 queries
