google has failed me... need wiring diagrams... - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 18th, 2006, 08:26 AM   #1
Bones
Bones's Avatar
Default google has failed me... need wiring diagrams...
I need the wiring diagrams for the GM SBC TBI oil sender and pressure gages (2 seperage gages) including colors
I also need them for the 3 wire GM alternators/starters, including colors....
anyone have a chiltons they can scan?
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old February 18th, 2006, 12:49 PM   #2
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
Yetti
Old February 18th, 2006, 12:56 PM   #3
Yetti
Yetti's Avatar
Yetti
Old February 18th, 2006, 01:04 PM   #4
Yetti
Yetti's Avatar
I have the wiring books from `91 for c/k & r/v & P trucks so if you have a need for a specific item let me know and I will scan it in.
Yetti
Old February 18th, 2006, 01:13 PM   #5
Bones
Bones's Avatar
thanks. I needed to know what the 31 pin on the oil sender did... aparently nothing.
is GRA Gray?
So if I read that right, it the oil sender gets too low, it will open the fuel pump relay? hmmmm
nother question
The fuel pump oil sender is normally open.... So if I don't hook it up (leave the 2 wires cut and taped), the computer will think I have good oil pressure right? Why wouldn't they wire it the other way (need to be closed to have a good reading)
The oil sender is next to the dissy, which is for the fuel pump I guess. There is also another one right above the oil filter. Is that one for the dummy light?
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old February 18th, 2006, 07:39 PM   #6
Yetti
Yetti's Avatar
the most stable oil presure is at the back by the distributor thats why most senders are there. the idiot light requires the presure to drop below 7 psi before it turns on the light, thats why its down by the filter.
the oil sender is normally open because if you loose presure(below 7 psi) the engine will die. and if you are cranking and it starts it will only run for 10 seconds on the relay timer till the oil sender takes over...so its very hard to run without oil.
and yes Gra is gray
Yetti
Page generated in 0.28477 seconds with 41 queries
