xj coil question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 10th, 2007, 10:39 PM   #1
xjrehab32
xjrehab32's Avatar
Default xj coil question
an xj coil is not flat on the bottom, so what do i do about mounting it when i swap my axle next week? i was planing on just making a flat bottom mount, but i dont know if i will have any ill effects.
i have checked around, ballistic fab, ruff stuff, poly, and no one has an "offset coil thing" like the xj does.
any ideas?
xjrehab32 is offline   Reply With Quote
Old July 10th, 2007, 10:51 PM   #2
zekexj
Cut one off from an XJ axle and adapt it to the new axle.
zekexj is offline   Reply With Quote
Old July 11th, 2007, 07:19 AM   #3
ajmorell
x2, or buy new spring mounts. The coil should be relatively flat along the top and bottom edges though.
Old July 11th, 2007, 09:51 AM   #4
PavementPounder
PavementPounder's Avatar
Originally Posted by xjrehab32 View Post
any ideas?
What do you think is going to happen to the bottom of the spring when the height of the vehicle is set upon it?
Old July 11th, 2007, 09:55 AM   #5
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
Lots of people build flat mounts, they work fine. Tha ballistic mount is made for tj/xj coils btw
Old July 11th, 2007, 12:13 PM   #6
xj4life
xj4life's Avatar
i'm pretty sure Rubicon Express makes replica of the OEM mount
Old July 11th, 2007, 03:50 PM   #7
xjrehab32
xjrehab32's Avatar
thanks guys, i will just make some flat mounts then.
Page generated in 0.28275 seconds with 44 queries
