removing rear cross member - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 10th, 2007, 08:06 PM   #1
Blackjackbender
Default removing rear cross member
I want to remove my rear crossmember because its cracking and weak. how should I do this.
I am going to weld in a support piece in front of it so the frame rails do not go out of line but was wonder what the best was to go about getting it so all there is left is two ends of the 2x4 frame rail.
thanks
Ty
Old July 10th, 2007, 09:00 PM   #2
1x1_Speed_Craig
Simplify...
1x1_Speed_Craig's Avatar
Why don't you crawl under and look where it's welded? It's very straightforward.
Craig
Old July 11th, 2007, 04:27 PM   #3
Blackjackbender
Craig
should i just grind the fucker out then? thats what I was planning on doing but thought i would ask to get someones opinion who has done it before.
Old July 12th, 2007, 01:11 AM   #4
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
I did this same thing but to my YJ... I figured since i'm going to be using the bumper for a pulling point whynot make the rear cross member strong!
I just took a grinder to the stock one and cut it between the frame rails. Than bought sqaure tubing (Got the thickest i could for the size...not sure what it is though now).
Welded that into place to the frame. Than i cut the other flimsly shit out that stuck out the sides that held the body mount points in. Used 1/4" plate and fabed up a new mount. I than took 1/4" plate and welded it between the seem of the crossmember and frame rail to give it more strength. Than added a plate to the bottom. Here are some pics....any questions PM me and if you want you can come over and look at it.
Page generated in 0.20843 seconds with 35 queries
