Lincoln locking - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 17th, 2006, 06:37 PM   #1
Pre4runner
Bike Dude
Pre4runner's Avatar
Default Lincoln locking
Ok i pulled the lock-right out and sold it, now im going ot lincoln lock my toyotas rear end....
Whats the most effective way of doing this?
Just weld up the spiders, weld them to the case... results?
Old February 17th, 2006, 06:52 PM   #2
brimy311
Smells like a Fork Liftis
brimy311's Avatar
Here is what I do for welding diffs. This DOES NOT work on C-clip axles however. But will definatly work on toyota.
Weld in a piece of metal on each side. If you want, I can cut a couple pieces and mail them to you.
JcrOffroad.com
Like us on Faceook!
Old February 17th, 2006, 07:18 PM   #3
Pre4runner
Bike Dude
Pre4runner's Avatar
I didn't think of doing that, and yea if you want to send me a couple of pieces that would be cool. ill pm you
Old February 17th, 2006, 10:04 PM   #4
brimy311
brimy311's Avatar
I will get those out on monday.
In order to really get good angle on welding a toyota carrier, you will need to remove the ring gear. Just be sure to torque everything back to spec when you get it all done.
JcrOffroad.com
Like us on Faceook!
Old February 17th, 2006, 10:24 PM   #5
Pre4runner
Bike Dude
Pre4runner's Avatar
yeah its removed already, needed to just to pull the lunch box locker out... Now it just needs to warm up a bit and i willn't mind stepping out into the garage
Old February 20th, 2006, 12:14 PM   #6
Sandals
Fucking Zen as Shit
Sandals's Avatar
I've used that same method on 44's, 60's, 35's etc all with great success. On my 60 I went the extra step and filled in the void between the spiders and the carrier, and welded that all in place.
And yes I know the carrier is cast, and I welded accordingly
Old February 20th, 2006, 04:48 PM   #7
shawn
Resident HVAC/R Jambi
shawn's Avatar
Well, it's cast steel, not cast iron (big difference).
Brian, that sure is perdy
Page generated in 0.17955 seconds with 44 queries
