Need Some Help - Page 5 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 14th, 2007, 09:17 PM   #81
Bones
Bones's Avatar
i did mine alone in about 4 hours, that included removing everything post turbo, installing a 3.5" Hypermax DP, making my own piping coming off the downpipe and exiting on the pass side of the rig just before the rear tire.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old July 14th, 2007, 09:25 PM   #82
boggin-machine
boggin-machine's Avatar
Originally Posted by bigcountrysg View Post
The only reason why the 7.3L was unable to meet the regulations due to the EPA changing the regulations on Diesel trucks. They also changed them again which is why the 6.0L was discontinued and the 6.4L was brought out. Also it is the reasoning for the diesel fuel to be changed from 500ppm of sulfur to 15ppm of sulfur.
Maybe you should do some more research before you open your mouth.
Then you maybe you will actually sound like you know what your talking about.
the 6.4 was brought how cause ford dont know how to build a damn motor after the 7.3 motor was dropped... all the lawsuits on the 6.0 motor they were forces to build a new diesel motor
Old July 14th, 2007, 09:40 PM   #83
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
From what I understand, the 7.3 PSD injectors were made by cat or someother worthwile supplier...Ford in its infinite wisdom went to a cheaper supplier / design on the 6.0L, hence the rash of injector problems.
@clarkstoncracker
Old July 15th, 2007, 01:20 PM   #84
bigcountrysg
Countryboy
bigcountrysg's Avatar
Ford does not build the any of there diesel engines. International does, Ford has had the contract with International to supply them with diesel engines for there light duty trucks for a long time. The first one ford used was a 6.9L, then the 7.3L, then the 7.3L turbo charged ( powerstroke was introduced at this time) then the 6.0L Powerstroke, now currently the 6.4L twin turbo Powerstroke.
bigcountrysg is offline   Reply With Quote
Old July 15th, 2007, 02:02 PM   #85
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Getcher exhaust swapped out yet?
@clarkstoncracker
Old July 16th, 2007, 08:34 PM   #86
bj house
bj house's Avatar
fyi the 6.0L had a couple other "differences" besides the injectors when comparing it to the 7.3.
Back on topic, what did you learn watching your hired help swap out yer exhaust?
Thanks RBB, ratchet straps for everyone :)
Page generated in 0.28640 seconds with 41 queries
