help me figure out what D44 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 2nd, 2007, 10:27 PM   #1
Default help me figure out what D44
help find out more about this D44
i got it on a trade and was gonna use it for a SAS swap on my B2
late 70's F250 Leaf sprung
what i know is that its a 3.54 ratio, the tubes are solid all the way to the knuckles, does not have c wedges welded to it confirming it a Leaf sprung, and its a High Pinion
bottom veiw pass side
bottom veiw drivers (aren't the 3/4 lcoking hubs different?)
top veiw of diff housing (i think someobdy welded a perch and bracket onto it, is the pad on the housing itself to the left the stock spring perch
top veiw pass side
Old July 3rd, 2007, 06:53 AM   #2
xjrehab32
xjrehab32's Avatar
its a leaf sprung HPD44 what else do you need to know?
http://77cj.littlekeylime.com/web_rs44.html
xjrehab32 is offline   Reply With Quote
Old July 3rd, 2007, 09:55 AM   #3
PavementPounder
PavementPounder's Avatar
It doesn't have the correct steering arm or driver's knuckle to be the 78-79 F-250, although it does have the dual-piston calipers of the heavier models.
Old July 3rd, 2007, 10:13 AM   #4
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
It looks like the studs were broke off on the knuckle. Someone must of switched the tie rod.
The newer fords have a wider spring centers so I would guess it was put under a newer one, hence the extra spring perch.
Old July 3rd, 2007, 12:43 PM   #5
PavementPounder
Give us a better (clearer) picture of the driver's knuckle top surface. Look for evidence that some studs were busted off flush with the top like Adam said.
I agree on the tie-rod. That's not the correct one.
Old July 3rd, 2007, 05:45 PM   #6
picture quality sucks cause my camera blows
heres one
yeah after looking real close, their was two studs on that knuckle that were cut flush, what were those studs for?
Old July 3rd, 2007, 06:00 PM   #7
boggin-machine
boggin-machine's Avatar
high steer
Old July 3rd, 2007, 08:32 PM   #8
Jeepaholic
Jeepaholic's Avatar
It is actually for push-pull type steering arm, like the chevys use. Although there should be 3 studs.
But yes it is also used for a high steer arm
Old July 3rd, 2007, 08:35 PM   #9
their might have been three, didn't look to close, just noticed the two and stopped looking
Page generated in 0.25666 seconds with 50 queries
