v8 swap - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 1st, 2007, 09:31 PM   #1
88mudder
In the band!
Default v8 swap
Im thinking of doing a 302 or 351 swap into my 88 bronco II. I want to retain my stock bw1350 t-case but really dont wanna spend the money for an adaptor plate.
What trans will bolt up to the 1350 without an adaptor plate? Im still not sure if i want an auto or manual trans.
Feel free to post up some tips in doing the swap!
Old July 1st, 2007, 10:59 PM   #2
88mudder
In the band!
also if anyone has a trans and 302 or 351w for sale let me know!
Old July 3rd, 2007, 05:25 PM   #3
88mudder
In the band!
ttt
Old July 3rd, 2007, 05:28 PM   #4
n8big
Size Matters
n8big's Avatar
Send a message via Yahoo to n8big
I think someone should do this for you!!
n8big is offline   Reply With Quote
Old July 3rd, 2007, 05:45 PM   #5
Tacker
Tacker's Avatar
You should just buy my truck
Old July 3rd, 2007, 06:29 PM   #6
88mudder
In the band!
i dont have 6,000 to spend
Old July 3rd, 2007, 06:31 PM   #7
88mudder
In the band!
thats what forums are for :miff:
Old July 3rd, 2007, 06:40 PM   #8
boggin-machine
boggin-machine's Avatar
i think what he is trying to say is that you shouldnt even attempt it if you cannt do a little research online about what mates to what and what not.. if that is beyond you then how are you going to swap in a small block ????
Old July 3rd, 2007, 06:41 PM   #9
Tacker
Tacker's Avatar
Try to find a early 80's C5 tranny with the correct tail housing and shaft to bolt to your 1350, they are kind of hard to find. My truck has a C5 tranny with a C4 bellhousing, converter, and valvebody which basically makes it a C4 with a couple small differences. I will see what I can come up with.
Old July 3rd, 2007, 07:13 PM   #10
88mudder
In the band!
im just like everyone else on here asking dumb questions :miff:
Old July 3rd, 2007, 07:14 PM   #11
88mudder
In the band!
thanks for the positive input to my thread!
ps. your suspension u sold me is working great on the 4x4 swap i did! Just thought id tell u.
Old July 3rd, 2007, 11:34 PM   #12
Tacker
Tacker's Avatar
Try and find a 83-85 Ranger or B2 with a auto tranny, More than likely it will be a C5. I am not positive on any of this info but I have read it in the past. You can either use the C5, or you can use the tail housing and tail shaft from the C5 on a C4 (have a shop do that). I give you credit for the things you are trying to do, hell for what you have already done by making your rig a 4x4. If you need info on this swap check out The Ranger Station, they have some good articles. If you have any other questions just shoot me a pm and I'll help you out however I can .
Old July 4th, 2007, 01:51 AM   #13
Bronco Sally
Lets go wheelin
Send a message via MSN to Bronco Sally
I just did mine not too long ago pretty easy let me know when you need to know and i will tell you. i used a c6 which was mated to a bw 1356 but is to wide for frame, so i picked up a np205 which bolts directly to the 1356 adapter just have to get a small spot drilled out(my buddy did that at a machine shop) But just let me know what you need and ill try and help ya. Cheers Mike
Bronco Sally is offline   Reply With Quote
Old July 4th, 2007, 03:43 AM   #14
Icebreaker88
Icebreaker88's Avatar
Yes you can use the tail housing from a C5 on a C4 trans to mate it to your stock T-case in the stock location. Thats what I did when I swapped a 302 into a 84 BII. It was originally a 2.8l with a C5 auto. I had the C5 tail housing swapped onto a C4 trans and everything bolted into the stock location
Also I have a early 80's 302 long block in good shape for $150.
[QUOTE=TurdBronco;1095911]I don't usually race cause it is still a focus.[/QUOTE]
Icebreaker88 is offline   Reply With Quote
Old July 4th, 2007, 11:44 PM   #15
88mudder
In the band!
may be getting a 351m next week. I did some research and i want to know if this setup will work. Mate a c5 tailhousing to a c4 tranny as well as a big block bellhousing to fit the 351m.
http://cgi.ebay.com/ebaymotors/Bellh...QQcmdZViewItem
Are all c4 trans floor shift? I need a floor shift version.
Old July 4th, 2007, 11:58 PM   #16
Tacker
Tacker's Avatar
Don't try and put an M motor in your truck :miff: they are too big and bulky, stick to the 302 or 351w. For the price of that bellhousing on Ebay you can buy a good Performance Automatic Ultrabell for a small Ford that is good for a 164 or 157 tooth flexplate and they are indestructable (thats what I have). Get a 302 it is the easiest swap to do due to its size. Get an aftermarket b&m shifter with a cable and put your shifter on the floor.
Old July 5th, 2007, 12:06 AM   #17
88mudder
In the band!
alright sounds like the M motor is bigger than the W. Ill stick with the 302 then because of its smaller size.
Page generated in 0.42936 seconds with 74 queries
