Which trans? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 1st, 2007, 07:41 PM   #1
88yj
collecting parts
88yj's Avatar
Send a message via AIM to 88yj
Default Which trans?
I have a G52 in my truck and a W56 sitting in the garage. I'm about to install my dual cases (as soon as the new x-member gets here) and I'm wondering which trans would be better to use. The W56 already has the cases bolted up to it, but the G52 is already in the truck.
Any strength advantages to the W over the G? Which should be longer? Thanks.
88yj is offline   Reply With Quote
Old July 1st, 2007, 09:04 PM   #2
hman1991
hman1991's Avatar
Send a message via AIM to hman1991
they r the same length but the w56 is supposeed to be the strongest.
hman1991 is offline   Reply With Quote
Old July 1st, 2007, 09:33 PM   #3
x2 The W56 is stronger.
Old July 1st, 2007, 09:51 PM   #4
88yj
collecting parts
88yj's Avatar
Thanks guys.
Old July 2nd, 2007, 08:07 AM   #5
brimy311
Smells like a Fork Liftis
brimy311's Avatar
The only problem your going to have is, You need 2 top shift cases to put dual cases on a W56. The case behind the W56 is a top shift, but the case behind the G52 is going to be a forward shift (means the tcase shifter mounts on the back of the trans).
The W56 has some larger bearings, but if you can't find another Top shift case, you may have to reuse the G52.
JcrOffroad.com
Like us on Faceook!
Old July 2nd, 2007, 08:19 AM   #6
artistic_gore
I own @ halo
artistic_gore's Avatar
Send a message via AIM to artistic_gore
He said the cases are already mounted to the W56 but the G52 is currently in the truck. I however know nothing of the issue at hand as I am still running L series trannies.
artistic_gore is offline   Reply With Quote
Old July 2nd, 2007, 08:31 AM   #7
88yj
collecting parts
88yj's Avatar
brimy, I already have 2 top shift cases adapted and ready to go. They are even mounted to the W56.
Old July 3rd, 2007, 10:15 PM   #8
brimy311
brimy311's Avatar
oh, ok. I thought it was just one top shift and waiting to install duals. Well then your good to go.
p.s I know nothing about toyotas anyways.
JcrOffroad.com
Like us on Faceook!
Page generated in 0.21401 seconds with 47 queries
