Differential Case Breaks (or, "Do I need a new carrier?") - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 28th, 2007, 09:07 PM   #1
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
Default Differential Case Breaks (or, "Do I need a new carrier?")
These are the most common axles you'll find. I left a few axles out because they pertain mostly to cars or are of no interest in using in an off road vehicle.
Differentials can be used "up to" the gear ratio stated and then you need a new gear ratio for the "and higher" ratio.
There are exceptions to these rules in that there are some gears that are made in a "thick" style that will fit the lower ratio carriers (most notably the Dana 44 4.10, 4.56, 4.88, and 5.13 ratios).
AMC 20 - up to 2.73 and 3.08 and higher
Chrysler 7.25" - All ratios
Chrysler 8.25" - up to 2.45 and 2.71 and higher
Chrysler 8.75" Tapered Pinion - All ratios
Chrysler 8.75" Straight Pinion - All ratios
Chrysler 9.25" - All ratios
Chrysler 10.5" - All ratios
Dana 28 - up to 3.45 and 3.73 and higher
Dana 30 - up to 3.54 and 3.73 and higher
Dana 35 - up to 3.31 and 3.54 and higher
Dana 44 - up to 3.73 and 3.92 and higher
Dana 60 - up to 4.10 and 4.56 and higher
Dana 70 - up to 4.10 and 4.56 and higher
Dana 80 - up to 3.73 and 4.10 and higher
Ford 7.5" - All ratios
Ford 8.8" - All ratios
Ford 9" - All ratios
Ford 9.75" - All ratios
Ford 10.25"/10.5" - All ratios
GM 7.5" (10-bolt) - up to 3.08 and 3.23 and higher
GM 8.5" (10-bolt) - All ratios
GM 8.875" (12-bolt) Truck - 2.54-2.73, 2.76-3.42, 3.73 and up
GM 8.875" (12-bolt) Car - 2.54-2.76, 3.07-3.90, 4.10 and up.
GM 9.25" IFS - All ratios
GM 9.5" (14-bolt semi-float) - All ratios
GM 10.5" (14-bolt full-float w/removeable pinion support) - up to 4.10 and 4.56 and higher
GM 11.5" (14-bolt full-float w/non-removeable pinion support) - All ratios
Toyota - All ratios
Jeeperz Creeperz, Inc.
1627 Eureka Rd
Wyandotte, MI 48192
734-281-8141
M-F 10am-7pm
Sat 10am-3pm
www.jeeperz-creeperz.com
Last edited by Jeeperz Creeperz; March 23rd, 2010 at 09:31 AM. Reason: Added Ford 7.5"
Old June 29th, 2007, 09:57 AM   #2
sglide
co captain of cubes pants
sglide's Avatar
if you would have done this two days ago the pm i sent you would have been alot shorter:tonka:
this is good info to have on here, thanks
sglide is offline   Reply With Quote
Old June 29th, 2007, 10:26 AM   #3
1x1_Speed_Craig
Simplify...
1x1_Speed_Craig's Avatar
Thanks for posting this, Jeeperz; good info.
One additional note for Dana 44s. "Thick" Dana 44 gears (e.g. - TJ) can be used with a 3.73 & down carrier. I'm running this setup in my CJ-10a, which has a '90 Grand Wagoneer Dana 44 front w/stock 2.73 carrier & 4.10 Rubicon gears.
Craig
Old June 29th, 2007, 10:44 AM   #4
Jeeperz Creeperz
GL 4x4 Vendors
Craig
I didn't really want to confuse the issue with thick/thin ring gears, modified cross shafts, etc. Currently there are 4 ratios that I'm aware of that will fit the 3.73 and down carrier Dana 44, but if you ever wanted to go to a 5.38 or 5.89 ratio, you'd need a new carrier, so I just went the least confusing route
1627 Eureka Rd
Wyandotte, MI 48192
734-281-8141
M-F 10am-7pm
Sat 10am-3pm
Old July 5th, 2007, 12:53 PM   #5
clarkstoncracker
lol
clarkstoncracker's Avatar
Whats the run down on gear width with the 14 bolts? I Remeber I had to purchase a new carrier to run the thick gears, because the thin gears weren't available.
Old July 5th, 2007, 01:01 PM   #6
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
CUCV 14 bolt have a 4:56 and up carrier (thin gears) but all non miltary run a 4:10 down carrier and run thick gears for 4:56 and up.
Old January 22nd, 2009, 06:38 PM   #7
nate4d
Gnarley Davidson
nate4d's Avatar
Send a message via AIM to nate4d
i have a 14 bolt with 3.56 can i use thick cut 4.56 gears instead of a new carrier? i heard somewhere that i can.
nate4d is offline   Reply With Quote
Old January 22nd, 2009, 06:48 PM   #8
PavementPounder
PavementPounder's Avatar
You can do that with any axle that thick gears are made for.
Old January 22nd, 2009, 11:10 PM   #9
nate4d
Gnarley Davidson
nate4d's Avatar
good to know thanx pp
Old September 11th, 2009, 03:35 PM   #10
TrailTamer
TrailTamer's Avatar
Send a message via AIM to TrailTamer
between the "thick" and "thin" gears
in general which is stronger/preferred? the "thick" sound like should be stronger??
TrailTamer is offline   Reply With Quote
Old September 11th, 2009, 04:01 PM   #11
PavementPounder
Thick/thin doesn't affect the teeth. The additional material is on the bottom of the ring (opposite side of the teeth).
Old September 11th, 2009, 05:36 PM   #12
Jeeperz Creeperz
GL 4x4 Vendors
The "thick" gears are to be used with a lower series carrier. Some differentials require a new differential to position the ring gear closer to the pinion (as the pinion head gets smaller for numerically higher gear ratios and thus moves away from the ring gear surface). The "thick" gears allow you to use the same carrier by using the extra material on the bottom of the ring gear to move the tooth side of the gear closer to the pinion.
1627 Eureka Rd
Wyandotte, MI 48192
734-281-8141
M-F 10am-7pm
Sat 10am-3pm
Page generated in 0.39032 seconds with 59 queries
