stripped hole in head :( - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 26th, 2007, 09:31 PM   #1
skife
skife's Avatar
Default stripped hole in head :(
i stripped a hole in the middle cam cap on my 22RE, anyone know if it would be alright if i helicoil this? or is it going to mess it up really bad? and throw everything out of wack.
Old June 27th, 2007, 01:13 PM   #2
Mud'N'Truck
I'll Finsh One, One Day
Mud'N'Truck's Avatar
Yes you can helicoil it. Talked to my friend that works at the machine shop and he talked to his boss and he said that is what they would do. There the #1 machine shop in the area so they know what there talking about.
Old June 27th, 2007, 03:17 PM   #3
skife
skife's Avatar
okay cool, as i said man, not your fault at all, it was torqed down once and was fine lol.
Old June 27th, 2007, 05:04 PM   #4
Mud'N'Truck
Ive had it happen before with other things. Stuff happens, no ones fault.
Old June 27th, 2007, 05:37 PM   #5
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
I have had to do it several times. Just be sure to drill straight and cover everything up so no metal gets where you don't want it. Make sure the helicoil is below the mating surface or it won't torque down right.
Old June 27th, 2007, 09:07 PM   #6
skife
skife's Avatar
okay thanks for the help, i'll drill it on a drill press. should be back in business in no time.
i'd really like to hit up that mounds run july 21st & 22nd trying to get my brother to go with me.
i'm a little worried i won't make it through everything being on 33"s and no locker.
i'll bring a strap.
Old June 27th, 2007, 09:31 PM   #7
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
i'll bring a strap.
Nothing makes it through "everything" at the mounds. :tonka:
Old June 27th, 2007, 10:04 PM   #8
Especially nothings with 33s..
Old June 27th, 2007, 10:51 PM   #9
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
hahahahaha
Old June 28th, 2007, 09:44 AM   #10
skife
skife's Avatar
i've got small tires
i've still got along ways to go on the yota to get it ready for mounds. to even get it ready for the street heh.
i want to go, hopefully i'll be there.
Old June 28th, 2007, 10:48 AM   #11
skife
skife's Avatar
mud'n'truck is this the cam you suggested?
http://www.jegs.com/webapp/wcs/store...0002_113552_-1
i was going to put the stock one back in but i think its bent. haha, its been in the warped head for 8 months
Old June 28th, 2007, 11:12 AM   #12
Mud'N'Truck
My cam spec:
Hi-Torque RV performance camshaft -257/268 advertised duration, 214/224 @ .050 lobe lift, 416/430" gross valve lift, 110 centerline -10 to 20 extra HP in the 1300 to 4800 rpm range
If you want to get a comp cam id get the next size up. That one is the 252s, id get the 260s cam.
Id get this cam. Almost the same as mine and it is cheaper then the crane cam.
http://cgi.ebay.com/ebaymotors/Toyot...QQcmdZViewItem
To bad about the stock cam, cuz i could have giving you the stock cam i had. Have like 3 of them. Good reason to get a nice cam though:tonka:
Old June 28th, 2007, 11:16 AM   #13
Mud'N'Truck
Youll be fine at mounds, you dont really need to worry about it. Jared had his jeep out there with 32 AT's and no lockers and actully went alot of places.
There if your truck is big its just the less you have to worry about getting stuck or a hole being to deep. It will probly be dry and shallow out there that time in the year any way unless it rains alot before hand.
Old June 28th, 2007, 08:58 PM   #14
skife
skife's Avatar
okay, i'm definatally a newb when it comes to wheeling, i've never done it before heh.
Old June 28th, 2007, 10:24 PM   #15
Just watch someone else go through the holes, first.
There's 36s under there somewhere..
Old June 28th, 2007, 10:33 PM   #16
Mud'N'Truck
x2
Thats how i wheel. Watch some one else do it first.
Thats the bad part about having the big truck in the group, is all your friends want you to go first.
Ill show you the ropes there. You dont need to worry about it, ull have fun.
Old July 7th, 2007, 11:41 AM   #17
BOGDOG
BOGDOG's Avatar
I was at thr mounds on the 4th and went a lot of places in a stock yota with 31" AT's. Stay out of the big ruts and go for it. It was real greasy in the areas with clay and the at's would not clear so steering was a bit rough at times. In the sandy areas and back in some of the tight trails it went anywhere I pointed it. I was there a couple weeks ago when it was real dry and went everywhere my buddys in there jeeps went except for a few big ruts. I also went places thet couldn't go. I drove thru one dry hole that my buddy tipped his cj5 on 36's in and we had to use 2 winches and a couple people as counterbalnces to get him out.
Old July 7th, 2007, 03:38 PM   #18
skife
skife's Avatar
i might not make it to mounds on the 21st, while putting the motor together today i noticed the timing chain tensioner isn't working, i've got ALOT of slop in the chain that is supposed to be new.
now i need to come up with money.
Page generated in 0.42500 seconds with 77 queries
