Trans not shifting past 2nd - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 25th, 2007, 09:37 PM   #1
mexdsk
goofy
mexdsk's Avatar
Default Trans not shifting past 2nd
Long raod trip hauling the jeep, Trans on the 1500 RAM (5.9 4x4) decided it did not want to shift out of 2nd gear.
Let it sit for a while and then it was ok again.
Got home doing that, but looking for ideas on what the issue may be, before I take it to the shop.
mexdsk is offline   Reply With Quote
Old June 26th, 2007, 05:56 PM   #2
user name
keep your stick onthe ice
user name's Avatar
sounds like its going into limp in mode, Probly just getting to hot pulling a trailer in this heat. Do you have an aftermarket trans cooler? if not you sould probly look into one undercooling is on of the biggest problems with dodge trans. also if it seams ok now i would at least get a trans filter and band adjustment.
Old June 26th, 2007, 08:28 PM   #3
mudd_jumper
mudd_jumper's Avatar
X2 my concord used to do this then the trans went by by
Old June 26th, 2007, 09:28 PM   #4
mexdsk
goofy
mexdsk's Avatar
To add to this ...
Today I drove it for 20 min it acted fine.
Let it sit (not running) for an hour, and the shift points were messed up, First gear wound all the way out, like I had the gas to the floor, then second did the same thing, and third and 4th seemed ok.
I guess I need to take it to a trans shop. I was just hoping somone had an Idea what it might be, for some reason I am leary of trans shops, perhaps becaus I do not know how to repare them my self and can't tell if they are BS-ing me or not.
Old June 26th, 2007, 09:30 PM   #5
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
If it went into limp-home mode, the MIL would be on and the trans would shift into direct-drive (3rd gear), not stay in 1st.
Your problem might not be the trans at all. Check the TPS first.
Old June 27th, 2007, 12:09 AM   #6
Monster4.0
Monster4.0's Avatar
What year is the truck?
Old June 27th, 2007, 06:07 AM   #7
mexdsk
goofy
mexdsk's Avatar
It is a very early 2001 (I purchased it in June of 2000) with 120000 miles, it has the 5.9 motor.
Old June 27th, 2007, 09:51 AM   #8
sodapop
Support the Sport!
sodapop's Avatar
hey Mike glad you made it over here to GL.
If no one can give you a recommendation up in Lake Orion, Ken has a very good tranny guy and will tell you the lowdown without worry of BS.
Old June 27th, 2007, 11:56 AM   #9
mexdsk
goofy
mexdsk's Avatar
Been here a long while .. just do not post very often ...
I will be takeing it to Tamaroff Dodge tomorrow (Thursday) hopefully to be repaired.
Ken did fax me the TSB today seems to fit my issue exactly.
Old June 30th, 2007, 01:32 PM   #10
mexdsk
goofy
mexdsk's Avatar
well the bad news is the Trans needs to be rebuilt.
Anyone know good trans shop in Orion/Rochester area?
Old June 30th, 2007, 03:20 PM   #11
mudd_jumper
there you go
Old July 1st, 2007, 05:07 PM   #12
mexdsk
goofy
mexdsk's Avatar
Originally Posted by mudd_jumper View Post
there you go
Well that is fine but I am looking for somthing local.. before I tow it all the way to Lansing, I dont think I would be able to drive it that far.
Old July 1st, 2007, 10:45 PM   #13
71jeepster
Glad I'm not Gay J. Hall!
71jeepster's Avatar
Send a message via Yahoo to 71jeepster
i thought mine needed a rebuild a while ago, turns out it was the shift soloniod, new one and a tranny flush and it was all good, they adjusted and checked everything while they were in there
71jeepster is offline   Reply With Quote
Old July 2nd, 2007, 07:48 AM   #14
A friend recently had a similar issue, on his there was a speed sensor that went bad.
Old July 2nd, 2007, 08:03 AM   #15
mexdsk
goofy
mexdsk's Avatar
Thanks
So how do I verify and or change the soloniod?
I would think that would be easy to do with out pulling the trans.
Old July 2nd, 2007, 10:05 AM   #16
You might PM swampjeep, there is someone in Lapeer who was recommended to us by KillerB for Dodge transmissions...
BTW, where in LO are you?
Old July 2nd, 2007, 11:45 AM   #17
mexdsk
goofy
mexdsk's Avatar
Thanks I will send PM.
I am off Joslyn south of Waldon in the Forest Hills sub.
Old July 2nd, 2007, 11:53 AM   #18
silverxj
Recovering XJ owner
silverxj's Avatar
Welcome to owning a Dodge.
I went with a dealer reman. 3yr/80,000 mile warranty.
Yours is doing the same thing mine did before it died.
Old July 2nd, 2007, 01:26 PM   #19
Tom
Because racecar
Tom's Avatar
Has anyone scanned it? it sounds to me like a governor pressure solenoid or the transducer has gone bad. it is an easy diagnosis with a scanner, and doesn't require removing the trans to repair.
Old July 2nd, 2007, 01:43 PM   #20
Bratworst
Bratworst's Avatar
X2
But nothing said about MIL fault codes, how the fluid looks, if it's full.
My car won't start...........it's (Chevy cavalier) what wrong?:tonka:
Bratworst is offline   Reply With Quote
Page generated in 0.46587 seconds with 83 queries
