22re Quit running - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 23rd, 2007, 12:15 PM   #1
jmdzuk
jmdzuk's Avatar
Default 22re Quit running
Just picked up a 86 4 runner for the family and dd for the summer .
It ran good drove it around the house for a bit (5 miles),and then all the sudden the charge light came on (battery is good ), then the auto trans wont down shift as well .And it wont start .
The only thing I did was take the top off and Power washed the engine bay ,but drove it for a couple miles after I washed it .
1986
22re auto
Thanks Jeff
jmdzuk is offline   Reply With Quote
Old June 25th, 2007, 08:38 AM   #2
Rattler
Home Sweet Homicide
Rattler's Avatar
I wouyld start with the basics. How is the battery? I had one for 4 months from Autozone and it was crap. I discovered this AFTER going through the pain of removing the alternator from a 22RE (you got to remove the lower coolant hose on an 89 XtraCab I know!). Sounds like something just got wet.
I really don't knw much about the older auto trannys.
Old June 25th, 2007, 11:16 AM   #3
kickstand
circling the drain
kickstand's Avatar
Sounds like the alternator pooped
Old June 25th, 2007, 01:05 PM   #4
skife
skife's Avatar
alternator looks fun to do on a 22RE.
Old June 25th, 2007, 05:17 PM   #5
roll-bar Bob
roll-bar Bob's Avatar
SEE IF IT HAS GAS !!!!
Old June 25th, 2007, 06:13 PM   #6
Dead alternator wouldn't cause those issues(not on an instant basis, at least. ), neither would no gas. You got something wet, like a main fuse or something. Go underhood and start checking(with a meter) all of your fuses.
Old June 25th, 2007, 10:28 PM   #7
kickstand
circling the drain
kickstand's Avatar
Ummm really? Cuz everytime I have lost an alternator the battery light comes on and very shortly following the truck dies....yup just like my 22re did after I smoked the alternator. Weird.
Is that tranny electronically controlled? If so I still say it is POSSIBLE not definately, but possible that it could be the alternator.
I am not saying some of the other suggestions are not hte case either....
Old June 26th, 2007, 11:38 AM   #8
Mud'N'Truck
I'll Finsh One, One Day
Mud'N'Truck's Avatar
Id try to jump start the truck. I had very similar problems when my alternator went out, also when my battery cable broke. Id Do all the things said earlier. Check fuses, battery, battery cables, and then if that does not fix it pull the alternator and have it tested.
Old June 26th, 2007, 12:22 PM   #9
Yes, its an electronically shifted trans. Hmm, the charge light will come on, but I've driven over 60 miles on a dead alterator before. You just are draining the battery.
If you open the hood on a 20 year old truck, spray it full of water, and then you have electronic malfunctions, the alternator isn't high on the suspect list.
Old June 26th, 2007, 01:07 PM   #10
Rattler
Home Sweet Homicide
Rattler's Avatar
Hell the new ones can do weird shit. I read some thread on Tacoma Territory about a guy power-washing underneath histruck. He got around the taillights too good and it wouldn't go out of gear some crazy shit like that. Maybe RBB knows what it is. I see he posts on there too.
Old June 26th, 2007, 09:13 PM   #11
kickstand
circling the drain
kickstand's Avatar
Makes perfect sense to me, alternator dies, truck runs for 5 miles or so, battery gets below 12 volts or lower, dead battery/charge light/whatever comes on, electronically controlled trans stops shifting, truck has no more juice, dies.
I've driven a long way on a bad alternator also, and I have also driven a very short way on a bad alternator. There is no telling if it is bad, how long it was bad for.
The alternator on my toyota died when I changed the timing chain, I dumped a bunch of coolant into it while undoing a hose.....the next time I ran the truck it died, alternator was smoking.....
All I am saying is it is an easy thing to change and a easy thing to test at the parts store, check it out.
Page generated in 0.44018 seconds with 56 queries
