XJ rear bumper - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 20th, 2007, 05:17 PM   #1
Thumper
Thumper's Avatar
Default XJ rear bumper
Last summer My grandpa and I built the front bumper and I made the rock sliderz, decided it was time for a swing out before headed back to college.
Welding in the reciever
Spindle arrived today, so further pictures will follow, any advice/ tips are appreciated.
Thumper is offline   Reply With Quote
Old June 20th, 2007, 06:44 PM   #2
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
Looks good so far. Make sure you tie it into the frame rails better. The extra weight of the tire and swing out will crack the 8 stock holes. I would run some .250" plate, with nuts welded to it, inside the frame rail useing the factory hatch holes. Then weld them to your mounting set-up you have.
Old June 20th, 2007, 06:49 PM   #3
Thumper
Thumper's Avatar
planning on doing some plating on the top, didnt think of using that to help tie it in, also am going to run some strapping to the bumper from where the old hitch mounted.
Old July 16th, 2007, 02:34 PM   #4
Thumper
Thumper's Avatar
Project complete.
Old July 16th, 2007, 08:32 PM   #5
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
Looks good! Spend a little more time with welding and grinding to make it look smooth, then it'll look even better
Old July 16th, 2007, 11:13 PM   #6
badazzamc
Get Some
badazzamc's Avatar
looks good.
Page generated in 0.16575 seconds with 41 queries
