Garmin eTrex Cx accuracy issues... - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > 4x4 Land Use > GPS tracks and trails
GPS tracks and trails 4x4 trails and destination coordinates
Old June 20th, 2007, 01:04 AM   #1
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
Default Garmin eTrex Cx accuracy issues...
The eTrex Cx series is notorious for having 20' +- accuracy problems with a few versions of it's software. There is an easy fix though.
First backup all your waypoints, tracks, routes and POI's on your PC.
Next download and install Web Updater
http://www8.garmin.com/products/webupdater/
Now install the newest software update for your unit using Web Updater.
After the update, power up your unit and make sure everything is working OK.
Turn the unit off.
Now do a "Hard Reset" of the unit by simultaneously holding down the center of the click stick (enter) and the button on the top right side (quit) then pressing the power button. The unit will ask if you want to reset all user data. (you backed everything up right )
After the reset make sure the unit is turned on and leave it in a place with a clear view of the sky for 20 min.
It will reacquire your location, and maybe even pick up a new bird or two. The accuracy problem should now be solved.
JcrOffroad
Zoom Zoom!
Old June 20th, 2007, 06:16 AM   #2
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Sweet. I'll do that tonight.
@clarkstoncracker
Old June 25th, 2007, 08:02 PM   #3
Mommabear
Happy Happy Joy Joy
Mommabear's Avatar
Nice, thank you! I'm going to try this next.
I should list my copy of Metro guide with a 64mb micro card if any one is interested in buying it.
Mommabear is offline   Reply With Quote
Old July 10th, 2007, 10:20 PM   #4
Trail_Fanatic
Member since 1994
Trail_Fanatic's Avatar
Wondering?
I already had the new update installed before I saw this.
I press the mentioned buttons and nothing happens.
Thoughts or ideas?
Trail_Fanatic is offline   Reply With Quote
Old July 10th, 2007, 10:27 PM   #5
Mommabear
Happy Happy Joy Joy
Mommabear's Avatar
It worked for me. I'm typically hitting 8 feet error range now.
Are you sure you're pressing them all at once?
Old July 11th, 2007, 10:53 PM   #6
Trail_Fanatic
Member since 1994
After closer review, I tried it with the unit off.
Worked fine.
Helps if you read all of the directions.:tonka:
THANKS!!!
Old July 12th, 2007, 06:46 AM   #7
shawn
Resident HVAC/R Jambi
shawn's Avatar
Hmm, I'll have to try that also.
Page generated in 0.84148 seconds with 44 queries
