popping in the front end - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 19th, 2007, 10:55 PM   #1
Blackjackbender
Default popping in the front end
there is a popping noise in my front end its one pop that occurs right after i start to accelarte or move. it only happens once. its a 2001 f-150 4x4.
any ideas. ill crawl under it tommrow but its to dark out and would like some ideas on what to look for since i have no clue what to look at on a 4wd ifs setup.
thanks
Ty
Old June 20th, 2007, 07:53 AM   #2
bj house
bj house's Avatar
I assume that you are talking about when it is in 4wd? Hi or Lo turning or straight or both? Just on accel or decel as well? How many mile?
Look for torn CV boots
Old June 20th, 2007, 11:28 AM   #3
Captain Ledd
Ranger Addiction?
Captain Ledd's Avatar
might be extra play in the axle, my rear axle clunks only once when I accelerate. Thats what I associate my noise with, of course mines got some decent miles on it..
but yeah, x2 on checking the CV boots.
Old June 20th, 2007, 12:27 PM   #4
bender
Your daily fullsize fix.
bender's Avatar
Send a message via AIM to bender Send a message via MSN to bender Send a message via Yahoo to bender
my truck does it, the g/f's exploder does it.... i'm starting to think it's a ford thing. is it like right in front of the passenger?
Old June 20th, 2007, 05:42 PM   #5
chris1044
chris1044's Avatar
Happen after you back up and put it in drive to go forward?? I've seen the ball joints on these trucks make that happen, and I've also seen the upper control arm bushings make that happen
Old June 20th, 2007, 06:04 PM   #6
88mudder
In the band!
my 88 ranger did it alot in 4x4
Old June 20th, 2007, 10:36 PM   #7
Blackjackbender
its got 108k on it so its probably wear i still need to get udner it. im almost thinking it could be a rear drive shaft u-joint or something.
Old June 20th, 2007, 11:43 PM   #8
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Your chit is broke.
There, that'll be 70 bucks labor for the diag work.
You check TSB's yet?
Old June 22nd, 2007, 01:28 AM   #9
Blackjackbender
Originally Posted by MuddyPaws View Post
Your chit is broke.
i havent checked shit yet
i can do all my own work. as much as you would like to think im not capable to do auto work I have restored a mustang perfectly besides body work and have painted a few cars. and have always kept my jeep running. I am more capable then most any student put of of any high school auto shop program
Old June 22nd, 2007, 02:19 AM   #10
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Never said you couldn't work on your shit.....
I said your shit was broke.
now it is $140 in diagnostic fees.
Old June 22nd, 2007, 02:27 AM   #11
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Hey, you sure it's really from the front?
I just looked up TSB's for your rig and they have one for a pop during accel for yours.
The problem is the rear driveshaft sticking on the t-case output shaft. You take it out, lube the splines and put it back on.
Something to check. We had to do that with a f250 in the shop this year.
Old June 22nd, 2007, 03:54 AM   #12
Blackjackbender
sounds like that could be it if it wasnt a u-joint
4wd is not on so the front end should not be under load so there should not be any real loud noise unless in 4wd. I will check it out.
thanks for the help.
Ty
Old June 22nd, 2007, 01:35 PM   #13
barry1me
Just another day
barry1me's Avatar
my 97 F150 4x4 did this and it was the lower ball joints...not a big deal.
barry1me is offline   Reply With Quote
Old June 22nd, 2007, 03:31 PM   #14
Blackjackbender
are they press in or bolt in?
Old June 22nd, 2007, 10:01 PM   #15
barry1me
Just another day
barry1me's Avatar
pressed in. Its really not that bad of a job though. If that is what it is make sure to get the ones with greese fittings...moog or TRW are good.
Old June 23rd, 2007, 10:47 AM   #16
liv2mx
i like jungle gym's.
liv2mx's Avatar
i have 3 f150's 97 01 and 03 if you need parts. my 01 is parts truck. i have pops in the front of mine but only when in 4x4. that is the cv shaft on mine. have broke 3 on my 03 and 1 on the 01. my 03 is lifted with 35's. it's eather cv or like what was stated ball joints.
Old June 23rd, 2007, 11:17 AM   #17
HVYRTFT
Reed my teef
HVYRTFT's Avatar
nice avatar yo
Old June 23rd, 2007, 12:06 PM   #18
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
take it to harolds frame shop in novi... $15 they look at the entire front end and write down things that need to be replaced.
Page generated in 0.47834 seconds with 77 queries
