look what i got today, for free!! - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > General 4x4 Stuff > Pictures and Video
Pictures and Video A forum for 4x4 related photos and videos
Old June 17th, 2007, 10:00 PM   #1
luvitmyjeep
broken
luvitmyjeep's Avatar
Default look what i got today, for free!!
so far all i know is that it's a 85 and has been sitting for about four years. i got it home cleaned the leaves and such out put in a battery and a squirt of starter fluid and it started right up! it's missing the air cleaner and no power gets to the doors of heater but i think it will be a great budget build.
so here's my question what do i got here? i'v seen what some of you know and i would like to know too! i think it has a 2.8gmv6 i'm going to do some searching now thanks
luvitmyjeep is offline   Reply With Quote
Old June 17th, 2007, 10:46 PM   #2
fukkinrizzo
Chrome Trucker Chicks Rul
fukkinrizzo's Avatar
cool, the way you drive you need a spare jeep
fukkinrizzo is offline   Reply With Quote
Old June 17th, 2007, 10:59 PM   #3
fullthrottle
2013 King of da Moustache
fullthrottle's Avatar
Send a message via AIM to fullthrottle
save your self the time and effort those 2.8v6s are dried turds!
fullthrottle is offline   Reply With Quote
Old June 18th, 2007, 07:30 AM   #4
Rattler
Home Sweet Homicide
Rattler's Avatar
You are so correct. My buddy had a Cherokee with one. It was a turd. A big steamy one at that.
Can't beat it for the $$ though.
Old June 18th, 2007, 10:55 PM   #5
luvitmyjeep
broken
hahahahahaha i drove it of the trailer and around the block. it's locked up tight in the rear but i cant get it in to 4wd or nutral i bp'ed it and it's on stands now but no luck. the front shaft spins like crazy but no engage! who got tricks? i am going to rip the diff apart tomarrow but i am keepin the 2,8 in there ntill it blowes!!! as of now there no 5th gear. how can i tell if its a ax15 or a peugot trans? hit me with a fish or send me a link! i can't wait to break this thing!!!!!
Old June 18th, 2007, 11:00 PM   #6
luvitmyjeep
broken
way to call it like you see it!!!! i'm no ritch kid but i'll put their dadddys rig to shame!! build it break it luv it! THATS HOW I ROLL!
Old June 19th, 2007, 12:23 AM   #7
nick_n_ii
nick_n_ii's Avatar
Send a message via Yahoo to nick_n_ii
That year it's not a AX-15
nick_n_ii is offline   Reply With Quote
Old June 19th, 2007, 07:26 AM   #8
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
the peugot(sp?) was the only manual availible behind the 2.8L IIRC
Old June 20th, 2007, 02:34 PM   #9
LuckyCharm4x4
LuckyCharm4x4's Avatar
Send a message via AIM to LuckyCharm4x4 Send a message via Skype™ to LuckyCharm4x4
could it be the AX4-4speed, it usually came behind the 4clyinders, but who knows?
~Bry
LuckyCharm4x4 is offline   Reply With Quote
Old June 20th, 2007, 02:51 PM   #10
Dave Kerwin
web wheeling, hard.
Dave Kerwin's Avatar
www.naxja.org
Old June 20th, 2007, 06:03 PM   #11
luvitmyjeep
broken
Old June 20th, 2007, 06:43 PM   #12
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
wouldn't that front axle have a vaccum disco. on the pass. side of the axle? if that doesnt engage then u wont have 4wd with an open dif.
Old June 21st, 2007, 06:01 AM   #13
luvitmyjeep
broken
where do the vac lines go to?
Old June 21st, 2007, 09:17 AM   #14
Grandman
do i look old !
Grandman's Avatar
I have to agree the GM 2.8 was not much of a motor . Lot of issues in the lower end . They did up date that motor at one time but i dont recall the year split . Even the up dated one was not much .
Front sounds like the vacuum motor is not engaging the outer axel . You do not have a chunk of gold there but you do have a toy which can supply some fun . Given the zero cost you can not loose .
Old June 21st, 2007, 10:54 AM   #15
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
Chances are it prob. wont work. but u can bypass it by either rigging up a cable (im sure if you do a search ull find a Write up about that) or if u pull the dissconnect cover off (located on the pass. side axle tube) u will see 2 axles shafts and a ring/gear thing, when u slid it over the two shafts will be connected. If you put the ring/gear thing in the right spot and use some hose clamps on each side then u should have 4wd. Another option is to find an axle shaft out of a non disco axle and just use the long solid axle shaft.
Hope this helps and i hope i didnt make any mistakes.
Old June 21st, 2007, 05:27 PM   #16
luvitmyjeep
broken
does this mean i need to have everything hooked up like the air box,and cleaner? i don't have them so can i just block off the loose hoses?
Old June 21st, 2007, 07:28 PM   #17
luvitmyjeep
broken
well i tried to get that box off but i broke all the bolts so i'm just guna weld everything!
Page generated in 0.31535 seconds with 73 queries
