FS 1990 Fullsize Blazer - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 17th, 2007, 03:00 PM   #1
bighabez
KD8ALB
Default FS 1990 Fullsize Blazer
Located in Frankenmuth, MI
I recently drove this about 450 miles back from school.
1990 Fullsize chevy blazer
about 190,000 miles on body/frame/engine
-10 bolt front 3.73 gears. 30 spline 8 lug outers
-14b ff rear 3.73 gears welded, shaved w drum brakes
-350 TBI ~190,000 miles Original
-700R4 tranny, no reverse
-NP241
-6inch lift (springs all the way around)
-OBA using stock AC compressor W/5gal tank
-MM12000 winch mounted on front Only used a few times($600 new)
-38.5x16-15 TSL's (a little bit of rash, but practically new, about 500 road miles only been on the trail a few times) ($1000+new)
-15x10 8 lug white spoke rims
-front seat pans have been replaced
-big ol steel front and rear bumpers
-power windows/locks
Other stuff: (pretty sure there is more, but this is what I can think of right now)
used 4.10 gears for front and back
28 spline carrier for 10b
2 long and 1 short shaft for front 10b
new rear shackles
NP241 with bent output shaft
Shaft for NP241 that should be able to fix transfer case
Painless dual battery kit
new drivers side battery tray
multiple shackles and straps
known problems:
no reverse
could use shocks
bad rear spring shackles (have new ones)
bad body mounts
wheeler body, not too bad, but a little beat up and rusted.
rear window does not power down, needs cable and probably simple wiring problem
I'm selling because I don't think I will be able to use it too often anymore. I have graduated from college and don't really have the room to have it sitting around either.
E-mail jmhaber@mtu.edu if you want pictures.
Asking $3000 OBO
Also willing to trade or partial trade for a chevy 1/2 or 3/4 ton pickup
bighabez is offline   Reply With Quote
Old June 22nd, 2007, 08:51 PM   #2
bighabez
KD8ALB
It was my daily driver for a while. Gas prices got a little high and I bought a car.
Page generated in 0.15290 seconds with 29 queries
