Valve cover bolts on 4.0? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 14th, 2006, 12:32 PM   #1
Muddyfun73
Yooper
Muddyfun73's Avatar
Default Valve cover bolts on 4.0?
Well I went and removed all the bolts for my valve cover and used two fingers to remove them all, except for the nuts that are on the studs. I know that can't be normal. Would it be ok to use loctite on these when I put everything back together?? I know they shouldn't be backing out on their own should they??
Muddyfun73 is offline   Reply With Quote
Old February 14th, 2006, 01:04 PM   #2
Captain Ledd
Ranger Addiction?
Captain Ledd's Avatar
A better solution is probably some lock washers. I'd just torque them down tighter (within reason).
Page generated in 0.14798 seconds with 29 queries
