dumb jeep ??????????? - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > General 4x4 Stuff > Classic Threads
Classic Threads Threads to good to lose! Now all found in one forum!
Old June 13th, 2007, 07:33 AM   #41
kickstand
circling the drain
kickstand's Avatar
I think mr. green is on to something with the side wheel drive thing. See if you go in reverse if the left side will spin, that will lead us somewhere.
Old June 13th, 2007, 07:37 AM   #42
pso728
pso728's Avatar
That side wheel drive thing never caught on though...apparently people didn't like going in circles on ice.
pso728 is offline   Reply With Quote
Old June 13th, 2007, 07:43 AM   #43
Mongo
Mongo's Avatar
Originally Posted by MuddyPaws View Post
Novak is incorrect.
The NP207 was used in the first year of Wranglers in 1987.
http://www.jeeptech.com/xfer/
The NP 207 is one of the weaker Jeep transfer cases, but can be upgraded. The NP 207 has an aluminum case and chain driven planetary reduction. Thankfully the NP 207 was installed behind some of the weakest Jeep power trains every used. It featured a 2.60:1 low range and a straight through design high range, but featured a driver side front output. It was used in one year of the Jeep YJ Wrangler 1987, and in the early XJ Cherokee's from 1984-1987
http://www.4x4review.com/tech/tCase-...de/default.asp
The NP207 was used in the first year of Wranglers in 1987. It was used in Cherokees (XJ) until from '84-'87 and replaced with the NP231.
http://www.jeepfan.com/tech/jeeptech...es-factory.htm
I found one page with conflicting info, but since it agreed with you, I left it out.:tonka:
Mongo is offline   Reply With Quote
Old June 13th, 2007, 07:51 AM   #44
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
Originally Posted by shawn View Post
He has a YJ, so he would have to jack the front tires off the ground, he doesn't have any lockout hubs!
YJ's have a vacuum disco. So the front shaft spins freely in 2wd...
JcrOffroad
Zoom Zoom!
Old June 13th, 2007, 07:53 AM   #45
pso728
pso728's Avatar
Nice return volley Daryl!
Old June 13th, 2007, 08:13 AM   #46
Tie Dyed
O.G.
Tie Dyed's Avatar
Send a message via AIM to Tie Dyed
Just do what monkey boy said.
I am guessing that your t-case is not shifting into 2hi.
Just take out your diveshaft and be done with this silly argument.
2000 XJ with a 3 inch body lift
Tie Dyed is offline   Reply With Quote
Old June 13th, 2007, 08:34 AM   #47
87'YJ
Jeeps, Journey and Jesus
87'YJ's Avatar
Your front driveshaft will spin in 2wd if it is truly in 2wd. Just climb under the jeep when its in 2wd (and not on!) and try to spin the shaft. If it won't spin, then go to a mechanic and figure it out.
87'YJ is offline   Reply With Quote
Old June 13th, 2007, 08:36 AM   #48
clarkstoncracker
lol
clarkstoncracker's Avatar
DO NOT DO WHAT 87'YJ SAID!!
If it doesn't spin, don't waste your money at the mechanic. Post up more here. we will help
Old June 13th, 2007, 08:50 AM   #49
captsolo
captsolo's Avatar
I think the easiest way to fix it is leave in the current 2hi position. Drive around a parking lot in tight circles for 10-15 minutes slowly then crank the wheels all the way to the left or right til the 4wd starts to bind and then MAT IT until something snaps. VIOLA no longer stuck in 4wd.
captsolo is offline   Reply With Quote
Old June 13th, 2007, 09:45 AM   #50
ckupq
Kitten I'm gonna eat you!
ckupq's Avatar
His vacuum disco is disengaged, but he has a locker. Or did you not read the part about side wheel drive.
ckupq is offline   Reply With Quote
Old June 13th, 2007, 09:49 AM   #51
shredder70
Chillin with the top off.
shredder70's Avatar
I can just feel the love....:dunie:
shredder70 is offline   Reply With Quote
Old June 13th, 2007, 10:35 AM   #52
Flexin' XJ
Flexin' XJ's Avatar
Yeah, it is being spread on pretty thick.
Flexin' XJ is offline   Reply With Quote
Old June 13th, 2007, 10:39 AM   #53
Mr.Green
I can levitate!
Mr.Green's Avatar
If it doesnt spin the other side in reverse then it is not a linkage issue. I forget what side these TCs normally get stuck in, this may be a common issue.
Old June 13th, 2007, 10:48 AM   #54
kickstand
circling the drain
kickstand's Avatar
Yeah it is the "drive" tire.
Old June 13th, 2007, 10:58 AM   #55
clarkstoncracker
lol
But most 4 wheel drive vehicles use the driver side as the drive side. I've never heard of a t-case getting stuck in passenger side drive only. I figured it would lock into the driver side.
He should just put in a selectable locker, like an ARB or something so he can control what tire he wants to drive the jeep.
Old June 13th, 2007, 11:20 AM   #56
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
Originally Posted by zxthunder View Post
and it only spins the front passinger side wheel. that is in 2 high
He said it spins the front passanger tire. That means that he can't have a locker, because the driver side would only get power with the disco unlocked.
haha we are going to run out of colors
JcrOffroad
Zoom Zoom!
Old June 13th, 2007, 11:23 AM   #57
Pokerob
hug life
Pokerob's Avatar
i think this may be a case of operator error
just light the jeep on fire and roll it off a cliff, oh yea go ahead and jump in.
Old June 13th, 2007, 11:26 AM   #58
RockyTop
Gimme the Busket!
RockyTop's Avatar
zOMFG!!11!!lolz!!1111! :dunie:
RockyTop is offline   Reply With Quote
Old June 13th, 2007, 11:32 AM   #59
CreativeFab
used to be Ironman
CreativeFab's Avatar
I tend to agree
Old June 13th, 2007, 11:37 AM   #60
Strangler
Strangler's Avatar
Subaru's have this "side drive" problem quite often......... Something about wheels that slip, wheels that grip?
Page generated in 0.60540 seconds with 83 queries
