dumb jeep ??????????? - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > General 4x4 Stuff > Classic Threads
Classic Threads Threads to good to lose! Now all found in one forum!
Old June 12th, 2007, 08:32 PM   #1
zxthunder
noditch2deepnohill2steep
zxthunder's Avatar
Default dumb jeep ???????????
ok i am new to the jeep thing. i have a 87 yj with a 305 v8 in it. when i jump on it it spins front and rear tires in 2 high. now it has dyna 35 with 410 gears. are the 87 yj all wheel drive? if so can i buy lockouts for a dyna 35?
thanks Marc
zxthunder is offline   Reply With Quote
Old June 12th, 2007, 08:50 PM   #2
shawn
Resident HVAC/R Jambi
shawn's Avatar
First off, wow.
Now, lets start to understand what you are asking. If it has a V8, then somebody swapped that in. So, what t/case is in there? I can't image you will spin all 4 tires in 2wd. So iether it isn't in 2wd, or you have an odd t/c in there. And the front axle is a Dana 30, not a dyna 35. There are hub kits for it (made by Warn) but it is much $$$.
shawn is online now   Reply With Quote
Old June 12th, 2007, 08:57 PM   #3
drummond
MTU 4x4
drummond's Avatar
Originally Posted by shawn View Post
First off, wow.
agreed. You should take some pictures of your stuff so we can take a look at it
drummond is offline   Reply With Quote
Old June 12th, 2007, 09:01 PM   #4
sglide
co captain of cubes pants
sglide's Avatar
First off, wow.
x2
sglide is offline   Reply With Quote
Old June 12th, 2007, 09:05 PM   #5
zxthunder
zxthunder's Avatar
dont no if the pics i have will be any help but if you tell me what you want to see i will take pics tomarrow. and it only spins the front passinger side wheel. that is in 2 high
Old June 12th, 2007, 09:07 PM   #6
shawn
shawn's Avatar
What does the tag on the back of the t/c say, that should tell you what t/c is in it.
Old June 12th, 2007, 09:08 PM   #7
clarkstoncracker
lol
clarkstoncracker's Avatar
Have you tried throwing your T-case into another gear?
Old June 12th, 2007, 09:19 PM   #8
Hacksaw
WWSD - What would stan do
Hacksaw's Avatar
Guess # 1) It has a TH350 and an NP203
Guess # 2) deeDeeDEE you are in 4wd gomer
Old June 12th, 2007, 09:21 PM   #9
Cooter
Dad Kickin' It OldSkool
Cooter's Avatar
NSFW!!
Old June 12th, 2007, 09:22 PM   #10
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
That's a 231.
Put the Jeep in 2wd. Try and spin the front drive shaft by hand.
JcrOffroad
Zoom Zoom!
Old June 12th, 2007, 09:23 PM   #11
sglide
sglide's Avatar
203s were a full time tc wernt they
Old June 12th, 2007, 09:38 PM   #12
TurdBronco
yes
Old June 12th, 2007, 09:45 PM   #13
Cooter
Cooter's Avatar
Looks like a 231 w/a SYE to me, as well.
The shift linkage is out of adjustment.
Old June 12th, 2007, 09:50 PM   #14
BlaineWasHere
GVSU Jeeper
BlaineWasHere's Avatar
Send a message via AIM to BlaineWasHere
you suck at taking pics...
BlaineWasHere is offline   Reply With Quote
Old June 12th, 2007, 10:10 PM   #15
zxthunder
zxthunder's Avatar
the pics wasent taken for this thread. it is a th350 trans. dont no what t/c yet. and it is in 2high and not 4 high.
Old June 12th, 2007, 10:11 PM   #16
zxthunder
zxthunder's Avatar
yes a tryed all of them.
Old June 12th, 2007, 10:14 PM   #17
xjmichigan
xjmichigan's Avatar
Lolz
Old June 12th, 2007, 10:38 PM   #18
SquirrelWJ
SquirrelWJ's Avatar
Send a message via AIM to SquirrelWJ
If one tire up front and one in the rear are spinning when you step on the gas, that means the front and rear are locked... as in it's in 4WD, most likely 4Hi. Just because the little shifter says it's shifted into "2WD", doesn't mean it is IN 2wd.
Get that shit looked at by a competent mechanic.
SquirrelWJ is offline   Reply With Quote
Old June 12th, 2007, 10:44 PM   #19
zxthunder
zxthunder's Avatar
in the t/c all the way up is in 2 high one click down is 4 high and the next is N. tryed them all. 4 low is hard to get into so the linkage is off but the t/c is going in 2 high. i just need to take it to DTS tomarrow and have them tell me what i have.
Old June 12th, 2007, 10:55 PM   #20
brewmenn
Mr. Special Snowflake.
brewmenn's Avatar
You don't seem to be understanding what people are trying to tell you. If there is power going to the front wheels IT IS NOT IN 2 HI The shifter may be in the 2 hi position, but it theres power going to the front wheels it has to be in 4-something.
Page generated in 0.91205 seconds with 83 queries
