*SOLD* '82 Wagoneer Limited (FSJ) - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 11th, 2007, 08:55 AM   #1
1x1_Speed_Craig
Simplify...
1x1_Speed_Craig's Avatar
Default *SOLD* '82 Wagoneer Limited (FSJ)
I just picked up an '82 Wagoneer Limited (FSJ) this weekend. It'll be a few weeks before I tear into this, but thought I'd put this out there as a heads-up. This is currently a complete vehicle.
EDIT: I'll sell this vehicle complete for $450.
  • 360 V-8 from '82 Wagoneer, 100K miles, newer reman carb, leaky valve cover gaskets, runs decent, but could probably use a tune-up (my buddy is a long-haul truck driver, and it has been sitting for several months). I just drove it around my yard, and it drives fine, too. Complete with all accessories minus A/C pump/bracket, and still in vehicle. $200
  • TF-727 trans from '82 Wagoneer, 100K miles, worked fine. $100
  • NP-219 t-case from '82 Wagoneer, 100K miles, $35
  • Dana 44 front axle from '82 Wagoneer, 100K miles, driver-drop, non-vacuum disco, 6 x 5.5" bolt pattern, 2.73 gears, great for YJ/TJ/XJ/ZJ swap, or CJ swap w/flipped D300. $200
  • HD AMC 20 rear axle from '82 Wagoneer, 100K miles, factory 1-pc shafts, 6 x 5.5" bolt pattern, 2.73 gears, excellent for YJ/TJ/XJ/ZJ/CJ rear axle upgrade, arguably as strong or stronger than a D44 rear. If you already have a weak CJ AMC 20, you can use your same gears/locker in this HD axle. $75
  • Other parts...just ask.
Craig
1x1_Speed_Craig is offline
Old June 11th, 2007, 10:01 AM   #2
boghog360
boghog360's Avatar
Does the waggy have a good cruise controll, ac compressor, and condenser,with lines that look good still. Im looking for these parts for a project.
Thanks
Dennis
boghog360 is offline
Old June 11th, 2007, 03:47 PM   #3
1x1_Speed_Craig
Simplify...
Thanks
Dennis
Everything is complete (A/C & cruise), but this Waggy isn't really road-worthy (leaky rear brake line), so I have only driven it around my yard. I have not tested out the cruise or A/C. I would sell all the items you mentioned for $40, though.
Craig
Old June 11th, 2007, 05:51 PM   #4
Trav
How much would you sell the whole thing for or would u trade for a 95' Poalris snowmobile? Trav
Trav is offline
Old June 11th, 2007, 06:33 PM   #5
deuce228
Redneck Poser
deuce228's Avatar
Sorry Craig is a butcher, he doesn't sell them whole, only parted out piece by agonizing piece.
BTW I am full of shit, I like to poke fun at Craig because he has bought, sold, and parted many of what i have not.
deuce228 is offline
Old June 11th, 2007, 06:37 PM   #6
1x1_Speed_Craig
Simplify...
EDIT: $450, and you can come drive it (around my yard) before you buy. Cash only...no need for trade items.
Old June 13th, 2007, 09:35 PM   #7
1x1_Speed_Craig
Simplify...
pics added
Old June 15th, 2007, 03:50 PM   #8
caveman
GeoDude
caveman's Avatar
how did that wood fender rust through?
caveman is offline
Old June 15th, 2007, 04:11 PM   #9
1x1_Speed_Craig
Simplify...
Thanks for the thread bump.
Old August 27th, 2007, 05:52 AM   #10
1x1_Speed_Craig
Simplify...
* Sold *
Page generated in 0.20092 seconds with 53 queries
