305/350 PCM interface question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 13th, 2006, 01:06 PM   #1
Bones
Bones's Avatar
Default 305/350 PCM interface question
Can a PCM from a truck with a 350 run a 305 motor? Only difference I know of are injectors......
Basically I have a PCM from a 350 in my jeep. I want to run a 305 while I rebuild my 350.... will it run or do I need a PCM from a 305? Trans is a TH400 so that doesn't matter.
EDIT- These are TBI motors...
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old February 13th, 2006, 03:30 PM   #2
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
I would say yes that the PCM can run the 305... It may run rich due to the fuel map. I have seen 305 PCM support 350's. The cam grind is different. The TBI's are all the same from the 5.0 to the 5.7, and I believe the 4.3 as well.
Old February 13th, 2006, 03:47 PM   #3
Thats my understanding as well.
If you were going to be running it for a long time, you could talk to someone like Howell, who could fix you up with a reprogrammed chip. Although could probably find a 305 ECU for the same cost..
As you noted, the injector sizing is different. So, after that, is mainly the ignition and fuel maps. I'd imagine the ignition curve is more or less the same, hard to say with the fuel maps.
Old February 13th, 2006, 04:44 PM   #4
Bones
Bones's Avatar
thanks, thats confirms what I thought.... now for the swap....
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old February 16th, 2006, 10:13 PM   #5
k5jess
k5jess's Avatar
I'm pretty sure the Proms are totally differnt. Check out thridgen.org they have everything you need.
k5jess is offline   Reply With Quote
Page generated in 0.22150 seconds with 38 queries
