CB Experts? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 13th, 2006, 01:05 PM   #1
purplejeep
Oldbie
purplejeep's Avatar
Default CB Experts?
I get a lot of interference from my fuel pump through my CB. Any suggestions?
purplejeep is offline   Reply With Quote
Old February 13th, 2006, 01:14 PM   #2
FlatFender
Tap Tap Splat
FlatFender's Avatar
Is it wired straight to the battery? or the Fuse panel?
If its wired to the battery, What are your SWRs? anything under 1.5:1 is acceptable
What antenna do you have?
Is your coax coiled anywhere, if it is, this can also cause some interferance. Remember, you only need as much coax to go from the CB to the antenna, no more. dont beleve it when you are told that it needs to be 18' lengths.
Some more info on your set-up would be helpful.
Check out this site www.cbradioforum.com
Old February 13th, 2006, 03:40 PM   #3
purplejeep
Oldbie
purplejeep's Avatar
It plugs into the cigarette lighter for now. I will be hard wiring it soon. Witch way is best?
SWR's ? Not sure what that is but I had someone hook up a meter to the antenna and that number was very close to 1.
My antenna is a white one. from Radio Shack. I do not have a bunch of extra coax.
It works great until I turn on the key and the fuel pump starts up. I can turn up the squelch and it works but then I tend to loose any weeker signals.
Old February 13th, 2006, 03:52 PM   #4
Is it actually fuel pump noise? Or is it ignition system related?
Old February 13th, 2006, 05:09 PM   #5
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
he probably has non resistance style wires on his ignition, seems to be the most common problem. you can get noise deading capacitors that clip into the power feeds and then you put a screw in the retainers to ground the body of the capacitor. check at radio shack or at a parts store.
Yetti
Old February 14th, 2006, 07:10 AM   #6
purplejeep
Oldbie
purplejeep's Avatar
It's not ignition noise. It starts and stops with the fuel pump...turn key fuel pump and noise runs for 3 seconds fuel pump stops noise stops.
I bought one of the in line noise reduction units. In the directions it told you to disconnect the antenna to see if the noise stopped. It did. So it's not coming through the power line it is coming from the antenna.
I wonder if it would stop if I put the antenna in the front?
Old February 14th, 2006, 09:31 AM   #7
Yetti
Yetti's Avatar
I wonder why the fuel pump is generating so much high frequecy noise? it seems like you have a ground issuse that is effecting your reception. is the antenna base grounded to the body properly? I just wonder how much noise you get if its removed and someone holds it where it is and the vehicle is running.
Yetti
Old February 15th, 2006, 07:03 AM   #8
purplejeep
Oldbie
purplejeep's Avatar
I disconnected the atenna from the mount last night and I still get the noise. I should have a good ground to the antenna...it's bolted to my tire carrier through threaded holes.
Old February 15th, 2006, 08:14 PM   #9
Yetti
Yetti's Avatar
http://www.sacskyranch.com/altnoise.htm
Yetti
Page generated in 0.30999 seconds with 50 queries
