8.8 axle metric vs 5x5.5 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 6th, 2007, 09:48 AM   #1
FORD FLARESIDE
just hockey
FORD FLARESIDE's Avatar
Default 8.8 axle metric vs 5x5.5
Okay, heres the scoop....................
I picked up an 8.8 low mileage, limited slip, disk brakes, to swap out with my original 8.8 with drum brakes.
I was told it was 5x5.5 wheel lugs.
It is not, it is out of the newer Fords, and has the metric pattern.
I would still like to put this under my truck, but I'm not sure if there is some type of conversion to 5x5.5.............maybe wheel spacers/adaptors, new axles, ect.........
Does anybody have any ideas?
Old June 6th, 2007, 11:54 AM   #2
Captain Ledd
Ranger Addiction?
Captain Ledd's Avatar
I thought the metric pattern was the same as 5x5.5, just measured in metric..
I'd be curious just to find this out too.
*edit:
just checked some things, it's 5x135mm = 5x5.31496063" So I guess it isn't. I can't imagine there wouldn't be some sort of adapter. If you changed the axles you'd have to change the brakes too.
Old June 6th, 2007, 12:38 PM   #3
FORD FLARESIDE
just hockey
*edit:
I am going to try to contact a wheel spacer manufacturer today, to see if there is an adapter.
..........I think my only other option, is to contact a machinest.
Old June 6th, 2007, 12:53 PM   #4
FORD FLARESIDE
just hockey
I found these,............
http://www.adaptitusa.com/
Would this be safe enough for a Mud bogger?
I'm afraid with the torque of a v8 and the traction of the 35inch boggers, there might be a problem.
Has anybody run anything like this?
Old June 6th, 2007, 01:52 PM   #5
sodapop
Support the Sport!
sodapop's Avatar
here's another option too
$100 for a pair
http://www.ezaccessory.com/Wheel_Ada.../5550-5135.htm
As for are they safe, there's varying opinions on them.
I've got 1 weekend run on mine plus some trailering, alittle over 300 miles so far. My jeep is only a 4 cyl. but I do have 35 x 16 x 15 boggers on the axle with the adapters. After the first day, I wheeled like I would have without them and so far so good. Mine are 2 piece which most consider even worse than the one piece ones. I bought mine from the website above which was the cheapest I could find.
Old June 6th, 2007, 02:03 PM   #6
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
What was the axle out of?
Full size trucks from 1980-1996 used the 8.8 with 5x5.5 bolt pattern. Rangers/Explorers use the 8.8 with 5x4.5 bolt pattern.
*edit: Just saw it was a newer truck axle - 5x135mm
Old June 6th, 2007, 02:08 PM   #7
FORD FLARESIDE
just hockey
I had my parts supplier run the numbers, and he said they match the axle out of a 99 E150.................I was told that it was a 5x5.5 by the seller, and I think the person who sold it to me honestly believed that. It's more my fault for not putting a tape measure across the studs.
I want to use this axle because it is very low mileage with the limited slip, and I want to run disk brakes.
Old June 6th, 2007, 02:17 PM   #8
Jeeperz Creeperz
GL 4x4 Vendors
You should be able to redrill the shafts and rotors to the 5x5.5 pattern.
Or, since it's a mudbogger, buy 2 wheels for it. They shouldn't be that expensive.
Old June 6th, 2007, 02:20 PM   #9
FORD FLARESIDE
just hockey
...........except the issue might be in the wheels themselves.
I think Ford sold this wheel lug pattern only in the 16inch and 17inch rim. I already have all my rims and tires,..and they are 15 inch.
Old June 6th, 2007, 02:36 PM   #10
tippy
SwampStomper
tippy's Avatar
[QUOTE=Jeeperz Creeperz;577347]You should be able to redrill the shafts and rotors to the 5x5.5 pattern.
I have done this to convert a 6 bolt to 5 bolt rear d44 axle, and it worked out fine, just be exact when laying it out.
tippy is offline   Reply With Quote
Old June 6th, 2007, 02:48 PM   #11
FORD FLARESIDE
just hockey
[QUOTE=tippy;577386]
Did you just drill between the existing holes, and then fill the old holes in?
Old June 6th, 2007, 02:53 PM   #12
tippy
SwampStomper
tippy's Avatar
On a 6 bolt I had to weld one hole closed to get a proper layout, in your situation I would just center between the existing holes.
Old June 6th, 2007, 02:59 PM   #13
FORD FLARESIDE
just hockey
Thanks, I think I'm going to try this.
The center hub on the axle, seems to be the same diameter as my old axle. I might be able to reuse my old axle, and just redrill the rotor.
Page generated in 0.41134 seconds with 62 queries
