1.6l overheating - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 6th, 2007, 08:20 AM   #1
ouchman
ouchman's Avatar
Send a message via Yahoo to ouchman Send a message via Skype™ to ouchman
Default 1.6l overheating
would the timming belt being one tooth off cause it to overheat?
support the sport- www.GLFWDA.org - member
Dear Travelers,
You won't see London and you won't see France, until we see your underpants!
Sincerely, TSA Officers
ouchman is offline   Reply With Quote
Old June 6th, 2007, 01:11 PM   #2
samuraijunkie
Remeber this?
samuraijunkie's Avatar
I don't think it would be the timing belt. Check you timing marks if it is fine then take out you thermostat see if that helps. I went through 3 thermotsats before i got one that worked.
samuraijunkie is offline   Reply With Quote
Old June 6th, 2007, 07:35 PM   #3
ouchman
ouchman's Avatar
the marks are right, ill try the stat
Dear Travelers,
Old June 6th, 2007, 10:40 PM   #4
Motor Slut
I put the Ick in Dick.
Motor Slut's Avatar
Also wash the outside of your radiator. They are large fin rads and get a lot of crud packed in them easily.
Old June 6th, 2007, 11:26 PM   #5
scottie
Eye candy
scottie's Avatar
or if you have the nasty aftermarket aluminium and plastic radiator it doesn't like to keep things as cool.
but yes, wash out the radiator really well, check the thermostat, timing, trunk monkey, water pump, coolant level, tire pressure, oil pressure, blinker piston compression, and exhaust for blockage.
Old June 6th, 2007, 11:46 PM   #6
samuraijunkie
Remeber this?
blinker piston compression, and exhaust for blockage.[/QUOTE]
I forget that everytime
Old June 7th, 2007, 12:01 PM   #7
ouchman
ouchman's Avatar
it is the plastic/aluminium but i changed that out for an all metal one, and i forgot about the trunk monkey.....thanx
Dear Travelers,
Old June 8th, 2007, 08:50 AM   #8
scottie
Eye candy
scottie's Avatar
did you just change out the radiator and now you have this problem?
Old June 8th, 2007, 09:51 AM   #9
ouchman
ouchman's Avatar
no changed the radiator to try to fix the problem, and i havent got it to over heat in the driveway, so it might be fixed
Dear Travelers,
Old June 13th, 2007, 09:05 PM   #10
vr
vr's Avatar
I'm using the stock '94 1.3 radiator with my 1.6 with no overheating problems even on the warm days like today.
People on Zuwharrie say both for and against the stock radiator causing overheating. Seems like the biggest pro is just having one that isn't clogged up.
vr is offline   Reply With Quote
Old July 20th, 2007, 03:14 PM   #11
caveman
GeoDude
caveman's Avatar
my overheating was a bad head
Page generated in 0.31498 seconds with 56 queries
