700R4 wires - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 12th, 2006, 07:33 PM   #1
SageJp
SageJp's Avatar
Default 700R4 wires
I just bought a 700R4 today to put into my '95 yj that has a chevy v-8. The trans came from a '86 chevy 4x4 truck.. my question is what do the two green wires on the drive side go to. Am I going to have trouble hooking this up in my jp.
Thanks for any help on this.
SageJp is offline   Reply With Quote
Old February 13th, 2006, 06:26 AM   #2
Quagmire
I can has layinframe
Send a message via Yahoo to Quagmire
neutreal safety switch
Google first.....ask questions later
Actually, the new rule of thumb is you should make your tires bulge slightly more then skooterbuilt when he's wearing his tight ladies pants
Quagmire is offline   Reply With Quote
Old February 13th, 2006, 10:52 AM   #3
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
Take a pic put is it a 4 prong conector with 2 wires? Are they "add on's" not factory looking. one with be a 12 volt source coming from a brake switch for the trans to unlock lockup. and the other will be a ground source. But you do need which one is which.
Old February 13th, 2006, 06:40 PM   #4
SageJp
SageJp's Avatar
heres a picture of the wires that are coming out of my trans.
Old February 14th, 2006, 09:37 AM   #5
KILLER"B"468
Yankabilly
My book shows that they are both 12v 0.5 amp circuts
A - being the outer wire, controlling a pressure switch that is NC (normally closed)
B - being the one closest the trans, controlling a pressure switch that is NO (normally open)
these switches are controlled by the computer for one, and the brake/vacuum switch for the other... there will be a ID # stamped on the pan rail on the opposite side of the pic you posted. At the back corner facing at you. Clean it off with a brillo pad and post the #'s. I will be able to get wiring schematics for that trans. There are 5 differnt (2 wire) applications.
Old February 14th, 2006, 10:14 AM   #6
SageJp
SageJp's Avatar
Killer"B",
the ID # is 6MRM247H
thanks for your help on this.
Old February 24th, 2006, 07:08 AM   #7
SageJp
SageJp's Avatar
I just bolted this trans and I still need help getting this trans hooked up right into my yj.
I would like to have this completed by tomarrow, so any help is appreciated.
Old February 27th, 2006, 09:53 AM   #8
KILLER"B"468
Yankabilly
was in florida... I will try to get you the wiring specs.
Old February 27th, 2006, 03:55 PM   #9
SageJp
SageJp's Avatar
Thanks "B"! I'd appreciate it.
Old February 28th, 2006, 08:09 AM   #10
jeepfreak81
81 inches of fun
jeepfreak81's Avatar
I wish I had pictures, I re-wired mine internally for the lockup without computer. It was so long ago i dont remember how though
I remember there was a pressure switch I had to replace to do this though.
Page generated in 0.19965 seconds with 53 queries
