disuccsion on non-centered recovery points - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 4th, 2007, 04:02 PM   #1
fukkinrizzo
Chrome Trucker Chicks Rul
fukkinrizzo's Avatar
Default disuccsion on non-centered recovery points
how many people use both of their hooks at the same time?
I use two short slings or a second strap run through the loop of strap hooked to the recovery vehicle. i do this when i am pulling my 16,000lb vehicle out. When i am pulling out a 6-8k vehicle i only use one bumper shackle cause i don't think the weight of the other truck is going to affect my truck.
i wonder how the manufacturer designed these hooks/points to be used? one at a time or both? a military recovery TM shows using a chain or a wire sling http://www.steelsoldiers.com/index.php?module=pagesetter&type=file&func=get&tid =1&fid=file&pid=63
I would like to note that using chain in recovery is OK if used properly. Most people don't know how to use it correctly.
Has anyone ever gotten any frame shimmy from pulling on one side?
I think that hooks from a stock truck should never be used on anything but a stock truck. That is what they are designed for. the weight and mire (stuck) factor of a stock truck vs a mod truck is a lot different.
thoughts or opinions on this?
fukkinrizzo is offline   Reply With Quote
Old June 4th, 2007, 04:19 PM   #2
Sandals
Fucking Zen as Shit
Sandals's Avatar
In the front of My YJ I have 2 3' Round Slings (rated at 30,000 lbs/piece) Basketed around the front Frame rail that come to Shackle to then attach to a strap or winch.
I've been trying to come up with a way to do similiar in the rear. I want to try to find something that will go through the stock holes from the rear leaf spring bushings.
Old June 4th, 2007, 04:21 PM   #3
Xrated
ASSHOLE
Xrated's Avatar
Never thought of it but that may be why some stocker hooks are mounted open ends out, instead of down or up.
Xrated is offline   Reply With Quote
Old June 4th, 2007, 04:26 PM   #4
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
well let me inlighten you. we do this test at work for sensors. we use 80 feet of 1/2 chain. we hook to something solid like a road grader(over 30,000lbs). we then hook it to the back in the vehicles at the Hitch. we have a solid steel hitch block our chain pins into, we then pull it 10 mph till it comes to the end of the chain. its a very solid point as the vehicles stop abruptly. now if you pulled like that on a frame corner you might not be going down the road straight afterwards. now to get to the point of this. I used to do frame work in a body shop. the pulling force to straighten an old CJ frame that had been diamond shaped was around 30,000 pounds of pull. so consider what it took to put the diamond in the frame?
Yetti
Old June 4th, 2007, 05:42 PM   #5
JEEPR
Playing Possum
JEEPR's Avatar
For a really good stuck I use a center mounted tow point. For an easy one I will use either a side mounted hook or the end of my bumper. I have 2" receiver mounts front and rear.
I also believe a chain is ok for recovery if it is a proper chain, used properly. A chain is for pulling, never for "snatching" a vehicle.
JEEPR is offline   Reply With Quote
Old June 4th, 2007, 06:19 PM   #6
FlatFender
Tap Tap Splat
FlatFender's Avatar
im a web-wheeler, I dont get stuck.
Old June 4th, 2007, 06:22 PM   #7
bigjay
The Man Myth And Legend
bigjay's Avatar
Location: i can piss on the allegan and barry county line at the same time.. ...
web wheeling is the only real wheeling..lol
bigjay is offline   Reply With Quote
Old June 4th, 2007, 06:30 PM   #8
Cooter
Dad Kickin' It OldSkool
Cooter's Avatar
I use individual hooks when recovering my rigs for obe 15 years- haven't bent a frame yet.
Of course- I will go to the winch (and snatch block, if necessary) rather than continue to fruitlessly use a strap on a hard stuck.
Old June 4th, 2007, 07:36 PM   #9
Grandman
do i look old !
Grandman's Avatar
Hurt the frame ? what frame , i dont have one .
Old June 4th, 2007, 08:06 PM   #10
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
I'll basket my rail in your rear, Mister.
@clarkstoncracker
Old June 4th, 2007, 08:37 PM   #11
C.K.
Dont Feed the Cyco
C.K.'s Avatar
C.K. is offline   Reply With Quote
Old June 4th, 2007, 08:48 PM   #12
x3
When I pull someone, I use my rear crossmember, which is designed for pulling (2.5" x 4" x 0.25" rectangular tube with a 4" x 0.5" thick tab running all the way through it welded front and back, with additional gussets).
The front, I use a 1" thick tab on each framerail, but I've beefed up and triangulated the front crossmember area.
Come to think of it, I've never had to be pulled forward, yet..
Backward, though
Old June 4th, 2007, 09:11 PM   #13
General
General's Avatar
X2 :tonka:
General is offline   Reply With Quote
Old June 4th, 2007, 09:25 PM   #14
Fraser
Fraser's Avatar
Originally Posted by General View Post
X2 :tonka:
X3
Old June 4th, 2007, 09:26 PM   #15
brewmenn
Mr. Special Snowflake.
brewmenn's Avatar
I usually use just one hook. I haven't noticed any problems with the frame. In the rear I've always used the trailer hitch receiver, again, no problems.
If you was to use a sling to 2 hooks it's OK, but make sure you look at and understand table 3 on page 33 of the vehicle recovery manual posted.
And I agree that chains have a place in vehicle recovery, but please make sure you know how to use them before doing so.
Old June 4th, 2007, 09:32 PM   #16
sglide
co captain of cubes pants
sglide's Avatar
when i have to get pulled in the welding rig (11,900#) i run a sling between the hooks, on the jeep i only hook one side
sglide is offline   Reply With Quote
Old June 4th, 2007, 09:44 PM   #17
General Lee
Slice of Starsage Anyone?
General Lee's Avatar
Send a message via AIM to General Lee
Originally Posted by Fraser View Post
X3
I used to have a frame...
but...when I got rid of it...I stopped getting stuck... :tonka:
General Lee is offline   Reply With Quote
Page generated in 0.46400 seconds with 73 queries
