TJ/ LJ wheelbase ?? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 12th, 2006, 02:34 PM   #1
C.K.
Dont Feed the Cyco
C.K.'s Avatar
Default TJ/ LJ wheelbase ??
I want to stretch the wheelbase of my TJ. I thought I could use the RE control arms from an unlimited. Any idea what the difference in control arm length is.
C.K. is offline   Reply With Quote
Old February 12th, 2006, 03:23 PM   #2
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
10" is the controll arm difference
TJ = 93.4" Wheelbase
LJ = 103.4" Wheelbase
Old February 12th, 2006, 04:56 PM   #3
fr3db3ar
KISS MY AVATAR
fr3db3ar's Avatar
So...you're saying that the control arms are mounted to the frame at exactly the same distance on the TJ and LJ. I find this to be unlikely. Just my $.02
Old February 12th, 2006, 05:59 PM   #4
C.K.
Dont Feed the Cyco
C.K.'s Avatar
You are probably right. If the LJ arms are 10" longer that might be a little longer than I want.
I guess I will need to find someone with an unlimited that has a RE LA kit on it and measure the rear arms.
Old February 12th, 2006, 06:51 PM   #5
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
When you use a Rubicon Express long arm kit the only difference is the rear control arm length. They both use the same skid plate that the arms are attached to. Unlike a Clayton long arm kit, Clayton mounts there arm's on the frame with new brackets.RE4030 and RE4040 are for a TJ and RE4050 and RE4060 are of a LJ. They don't make a different crossmember (RE4200) for a LJ.
If you talking about a short arm kit the front and rear lowers and uppers on both a TJ and LJ are they same. On the LJ the mounts for the control arms are 10" farther back on the frame rails.
Old February 12th, 2006, 10:45 PM   #6
TJrockdogg
Living on the Edge
TJrockdogg's Avatar
I would like to throw in my $.02.
I used to work at Jeep for a sub-contractor. I personally didn't see much difference in the front at all, but the rear is another story. I can't say for sure that the rears are definately longer, mainly because chrysler stretched the frame between the axles rather than mess with an already proven suspension.
now speaking after market suspension is completely different story, I would definately get my facts straight before doing any major retuning.
just my $.02
TJrockdogg is offline   Reply With Quote
Old February 12th, 2006, 10:49 PM   #7
nixxerRsixxer
Homewrecker
nixxerRsixxer's Avatar
RE uses the same skid plate for TJ and TJ Unlimited.. yes the longarms are that much longer.. :/
nixxerRsixxer is offline   Reply With Quote
Old February 13th, 2006, 08:30 AM   #8
C.K.
Dont Feed the Cyco
C.K.'s Avatar
just my $.02
Thanks for the input. I am just going to call RE.
Old February 13th, 2006, 08:38 PM   #9
Skooter_Built
Fuck talk, Duck walk!
Skooter_Built's Avatar
I believe that Blue Touch fab is comming out with a kit to stretch a TJ's wheelbase. From what ive heard it involves a new 16 gal tank and a few other pieces, but it allows you to move the rear axle back 6 inches. You could also got the extreme route and remove the gas tank, install a fuel cell inside, move axle back, cut off upper spring mounts and reposition them for proper spring angle...
I'm the man in White.
Skooter_Built is online now   Reply With Quote
Old February 13th, 2006, 08:50 PM   #10
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
BTF has 2 versions? 1 sits under the Jeep, in the stock location, but moved back. The other version, will bolt in behind the seat, using factory bolt holes in the tub. Nth degree has one that is going to come out round Easter Jeep Safari. It moves the rear axle back 5" and uses a new 16 gal. fuel tank that uses stock TJ parts. Clayton also makes a stretch kit ,but no fuel cell.
Old February 13th, 2006, 09:41 PM   #11
C.K.
Dont Feed the Cyco
C.K.'s Avatar
I already have the fuel cell for behind the seat. As for the spring perches, they will be cut off to make room for coilovers. Just need the arms. I want to use Re because i just got the RE tri link set up installed. I talked to Re today. They said the arms are about 10" longer, as Rocky said. The problem is the dont have a tri link set up for the LJs yet.
Page generated in 0.25615 seconds with 56 queries
