my Toy log: 6/2/2007 - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 30th, 2007, 01:33 PM   #21
skife
skife's Avatar
payday was yesterday, i'm almost broke again.
ordered a cam from summit with these specs:
Camshaft, Mechanical Flat Tappet, Advertised Duration 260/260, Lift .434/.440, Toyota, Each
a little more lift that you suggested and a little less duration.
it says it won't work with computer controlled stuff, i don't see much difference in it compared to the cam you posted except the cam you posted has a split duration, will that effect it much?
also ordered a TRD t-shirt from TRD :D
Old July 9th, 2007, 10:46 AM   #22
skife
skife's Avatar
between then and now.
threw the motor together, everything was good, got the head on. on look... the timing chain is loose as a $3 hooker. i was told it was new... everything up front was supposed to be new...
so, today i spent $82 on a head gasket, a timing chain, gears, a tensioner and guides.
This motor will be practically new when i'm done.
Old July 14th, 2007, 05:24 PM   #23
skife
skife's Avatar
7/14/07 motor is in, missing ALOT of bolts and the power steering tensioner pully, i think the mechanic at work was messing with my shit and some of it is gone now.
still need radiator in, vaccume nightmare hooked up, starter put in, alternator hooked up. and key turned :D
Page generated in 0.19555 seconds with 32 queries
