my Toy log: 6/2/2007 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 3rd, 2007, 09:16 AM   #1
skife
skife's Avatar
Default my Toy log: 6/2/2007
got out of work at 1, and i store my broken '92 truck behind my work.
waiting for my dad to get out of work, had to run som erands and such.
we get to my truck at about 4.
Busted ass, worked really hard and finally got the bad 22RE out of the truck at 9pm apparently the motor was rebuilt 40k miles ago, well the idiot that rebuilt it never put new frost plugs in it, the rear frost plug had a rust hole in it wich caused it to overheat.
anywho, motor is out and it was a PITA, but i now know how it goes back together :D
debating on getting my motor rebuilt or finding a different 22RE
Old June 3rd, 2007, 04:13 PM   #2
Pre4runner
Bike Dude
Pre4runner's Avatar
find another one to put in, i took the time and money to rebuild mine and did a lot of top end work to just blow it up again because of my big right foot.
Old June 3rd, 2007, 04:21 PM   #3
x2
I've been running over a year on a replacement motor, unknown miles, but runs good. Truck it came out of rusted its frame in half.
If anything, leave the bottom end alone, and refresh then top end...
Old June 3rd, 2007, 05:01 PM   #4
skife
skife's Avatar
i've actually got 2 motors right now, one is in pieces and i dont know the mileage.
i'm thinking of buying a parts truck anyways. someone had a rolled 4runner for $600
Old June 3rd, 2007, 05:08 PM   #5
Pre4runner
Bike Dude
Pre4runner's Avatar
i know which one you're talking about, i almost bought it for the drive train, but then i sold my yota
Old June 3rd, 2007, 09:20 PM   #6
skife
skife's Avatar
i'm thinking of buying it, cutting the roof off and building a roll bar and wheeling it this summer, then this fall put the motor in my truck and part the rest out.
Old June 4th, 2007, 06:09 PM   #7
hman1991
hman1991's Avatar
Send a message via AIM to hman1991
let me know if u get it i may be interested in the removable top.
hman1991 is offline   Reply With Quote
Old June 5th, 2007, 09:20 PM   #8
skife
skife's Avatar
Log for today, 6/5/07
pulled the head off the motor cylinder bores look great, like the motor was rebuilt 40k miles ago, just like some jackass didn't change the frost plugs.
taking the head in to be checked to see if its warped or not, if it is warped i'm going to get it milled.
also thinking of getting a new cam since i've got the head off. any suggestions?
Old June 5th, 2007, 10:52 PM   #9
You can't go wrong with a comp 252S cam.
Old June 5th, 2007, 11:12 PM   #10
Pre4runner
Bike Dude
Pre4runner's Avatar
Keep it mild, the comp 252s would be a good choice, i had a 262, took a long time to get it running right
Old June 6th, 2007, 06:22 PM   #11
Mud'N'Truck
I'll Finsh One, One Day
Mud'N'Truck's Avatar
I would put a cam in for sure. Made a huge difference in power in my 22re. Made the power alot sooner in my truck. If you want another motor for parts i might have one for sale in a month or so. Think it might have spon a bearing. Still runs, just needs a rebuild. Its out of a 92 pickup(22re). Im putting the motor out of my 85 in the 92 and putting a built 350( really 357) in the 85.
Old June 6th, 2007, 06:26 PM   #12
Mud'N'Truck
Hi-Torque RV performance camshaft -257/268 advertised duration, 214/224 @ .050 lobe lift, 416/430" gross valve lift, 110 centerline -10 to 20 extra HP in the 1300 to 4800 rpm range
Thats the spec's on the cam I used. Got it off of ebay for like 70 bucks
Old June 8th, 2007, 02:17 AM   #13
skife
skife's Avatar
mud'n'truck how does that cam do on gas mileage though? does it compleatly kill it or is it just 1-2 mpg?
i'd really like to pick up some power and not lose much mileage.
Old June 8th, 2007, 07:45 AM   #14
A cam like the 252S isn't going to hurt your mileage, might help it. Its designed to increase low end torque, which helps you by not having to stand on the gas as much.
Old June 8th, 2007, 10:13 PM   #15
skife
skife's Avatar
forgot to update yesterday.
6/7/07:
Took the head in to the local machineist and he said its warped, and then showed me how the cam wouldn't spin freely in the head. He also said there is a way to bend it back. some jig that you put shims and bolt it down the put it in the oven, i dont know anything about it though.
Old June 8th, 2007, 10:17 PM   #16
Mud'N'Truck
I get real bad milage but i dont think its because of the cam. I think hagger is right with the better milage because it makes the power sooner which means you dont have to give it as much throttle.
Old June 10th, 2007, 07:05 PM   #17
skife
skife's Avatar
oh okay, thanks guys.
I'm excited to get this truck moving under its own power again. :D
Old June 23rd, 2007, 06:44 AM   #18
skife
skife's Avatar
6/23/07: Not alot of progress lately i've been waiting for a head, going to have all the parts to put the motor together today. Last night i scored a set of rims and tires for $75
the 6lug pattern on these trucks are the same as chevy right?
Old June 23rd, 2007, 01:11 PM   #19
Mud'N'Truck
the 6lug pattern on these trucks are the same as chevy right?[/QUOTE]
Yes they are, only thing is that the centers of the rims are somtimes to small for the toyota hub.
Nice talking to ya, thanks for buying the head, good luck getting it running.
Hope the u joint didnt go out on you on the way home.:tonka:
Old June 23rd, 2007, 10:24 PM   #20
skife
skife's Avatar
Hope the u joint didnt go out on you on the way home.:tonka:[/QUOTE]
we made it all the way home :D thanks agan man.
if the insides of the wheels are to small i'll have them machined to fit. they look like they'll fit i want to throw them on there just to see though :D
Page generated in 0.43687 seconds with 83 queries
