30 spline dana 60 strength - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 2nd, 2007, 10:22 AM   #1
rustcharger
dubs ain't sh*t
rustcharger's Avatar
Default 30 spline dana 60 strength
Is it possible for 30 spline dana 60 axles to have any kind of decent lifespan with big tires (40") or is it unwise to even attempt it. It would be in an 88 dodge 1/2 ton less than 350 hp.
rustcharger is offline   Reply With Quote
Old June 2nd, 2007, 10:37 AM   #2
Cooter
Dad Kickin' It OldSkool
Cooter's Avatar
If you are street only, go for it. If you are going to wheel it with a locker, I would look into putting some 35 spline shafts in it.
Old June 2nd, 2007, 10:47 AM   #3
mudrunner456
mudrunner456's Avatar
i had 30 spline stubs in my 60's and only 38's and i broke one on each side. But i had lockers and around 400 horse.
mudrunner456 is offline   Reply With Quote
Old June 3rd, 2007, 02:00 AM   #4
TurdBronco
I ran 42's on a fullsize bronco with a 460 and a welded front. Never broke one. Depends on how you wheel it.
Old June 9th, 2007, 04:51 PM   #5
overbuiltyj
overbuiltyj's Avatar
If you like the rocks at all,dump the 30s as soon as you can afford.1 broken stub can cost more than the upgrade if you take out the spindle,wheelbearings,and lockout with the stub.Not to mention what a PITA it is to torch the spindle nuts out in a field.Just my opinion, was running 39 IROKs with a tired old 350 and not spinning the tires with new spicer stubs.
overbuiltyj is offline   Reply With Quote
Page generated in 0.24441 seconds with 38 queries
