Rims size? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 1st, 2007, 11:12 PM   #1
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Default Rims size?
I want to run 33's on my dakota and im not sure what size rims to get anyone know what will fit? 33 X 12.5's
Old June 1st, 2007, 11:25 PM   #2
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Does anyone know if when i crank the bars on my truck will i need to do an alignment?
Old June 2nd, 2007, 05:42 AM   #3
Viperdave
A-1 Dave Costa
Send a message via AIM to Viperdave
run a 15x8 or a 16x8 depending on what year dakota it is...
Viperdave is offline   Reply With Quote
Old June 2nd, 2007, 12:06 PM   #4
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
Cranking the bars is pointless. You may gain a 1/2 inch.
Do it the right way, not the cheap way.
Yes you would need an alignment, but understand you are changing the geometry of the suspension incorrectly and may not be able to get all angles back to factory spec.
You will want camber and toe in spec, as they will cause tire wear. You may not be able to get caster in spec, but that will more or less just change steering feel.
Old June 2nd, 2007, 01:07 PM   #5
Viperdave
A-1 Dave Costa
not to mention the 33s you want to run fit without cranking the bars...
Old June 2nd, 2007, 02:38 PM   #6
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
doubtful
Old June 2nd, 2007, 02:53 PM   #7
Viperdave
A-1 Dave Costa
Originally Posted by MuddyPaws View Post
doubtful
truthful, my 33's fit on my 04 dakota without rubbing... my bro's 02 also has them without rubbing... dont forget we are talking 3in lift
Old June 2nd, 2007, 06:30 PM   #8
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
It will depend on the backspacing of the wheels you are using, and will also depend on your definition of "fit".
Did a 97 a few years back and there was rubbing on the frame at full lock and a bit of rubbing on the plastic closest to the door. Had to trim a bit to make it quit. This was on stock rims.
Old June 2nd, 2007, 06:45 PM   #9
Viperdave
A-1 Dave Costa
to me, fit is no rub lock to lock
Page generated in 0.35805 seconds with 50 queries
