axle id?? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 31st, 2007, 06:21 PM   #1
sQUEAK003
Irish R&B Singer
sQUEAK003's Avatar
Default axle id??
can someone point me in the right dirrection on the thread on how to figure out what axle i got out of the 96 cherokee i got.....
'09 "Sparkly Tan" Jeep Patriot
http://badges.fuelly.com/images/smallsig-us/306663.png
CLICK HERE TO GET RID OF ME
Originally Posted by PCK_4xCustoms View Post
cunt punt, it's like a reset switch for women.
sQUEAK003 is offline   Reply With Quote
Old May 31st, 2007, 06:26 PM   #2
ddeadserious
ddeadserious's Avatar
http://www.greatlakes4x4.com/showthread.php?t=57
I'm assuming we're talking rear axle.
It's not a 44, those were only offered in 87.
It's either a Chrysler 8.25(will have an obviously flat bottom) or a 35(not a flat bottom)
ddeadserious is offline   Reply With Quote
Old May 31st, 2007, 06:29 PM   #3
Sandals
Fucking Zen as Shit
Sandals's Avatar
Most likely a chrysler 8.25
Old May 31st, 2007, 07:50 PM   #4
Cooter
Dad Kickin' It OldSkool
Cooter's Avatar
Not true- from '87-'89
Old May 31st, 2007, 07:56 PM   #5
ddeadserious
It's from a 96, so it wouldn't matter if I'd have said they only offered them in 81.
Old May 31st, 2007, 08:02 PM   #6
Cooter
Cooter's Avatar
Bad tech is bad tech, no matter how many excuses you use.
Old May 31st, 2007, 09:01 PM   #7
sQUEAK003
Irish R&B Singer
sQUEAK003's Avatar
here is a pic
Old May 31st, 2007, 09:09 PM   #8
ddeadserious
That's an 8 1/4.
Old May 31st, 2007, 09:09 PM   #9
ddeadserious
you win.
Old May 31st, 2007, 09:28 PM   #10
sQUEAK003
Irish R&B Singer
sQUEAK003's Avatar
thanks alot for the GREAT tech info:miff:
Old May 31st, 2007, 09:30 PM   #11
sQUEAK003
Irish R&B Singer
sQUEAK003's Avatar
now for the gear ratio.....what ratios did they come with???? or send me the the thread with the turns and math cause i once again can't find it in the search......i suck at the intra net....or just the search on here
Old May 31st, 2007, 09:35 PM   #12
Cooter
Cooter's Avatar
Open diff- jack up one rear tire and rotate it two turns while counting driveshaft rotations. Limited slip- jack up both tires and rotate them one turn. (While in nuetral/ front wheels chocked) for both of the above tests)
Your amount of driveshaft rotations will be your gear ratio. (If you jack up one tire and it doesn't turn easily in nuetral, then you most likely have a limited slip)
Old May 31st, 2007, 11:17 PM   #13
sQUEAK003
Irish R&B Singer
sQUEAK003's Avatar
its already removed from the jeep so would i have to hold one side with something and spin the other our should it not matter......an if i rotate it 2 times and count the roatatoin of the drive shaft yolk say it rotates 4 times what would be the ratio
Old June 1st, 2007, 06:24 AM   #14
Cooter
Cooter's Avatar
Ether both axles have to rotate at exactly the same time and you rotate them one revolution, or you have to keep one from spinning and rotate the other 2 revolutions.
If the axle is already out of the Jeep, set it on two jackstands with the pin ion facing down, pull the cover, and look for the ratio on the ring gear. If you don't have the ratio stamped on the ring gear, it may have the ring and pinion tooth counts. (It will look something like 41:10 for the tooth counts)
Old June 1st, 2007, 08:04 AM   #15
clarkstoncracker
lol
clarkstoncracker's Avatar
holy cows, not only is he back, but hes helping people. :tonka:
Old June 1st, 2007, 05:03 PM   #16
Cooter
Cooter's Avatar
Hey, it has happened before. :tonka:
Old June 1st, 2007, 10:56 PM   #17
Viperdave
A-1 Dave Costa
Send a message via AIM to Viperdave
3.07 - used with 4.0L engine / manual transmission
3.31 - only available on older (pre87?) 2 door XJs with "Fuel Economy" package
3.55 - used with 4.0L engine / automatic transmission
3.73 - found in some XJs with the towing package
4.10 - used with 2.5L engine usually, and older XJs with the "Off-Highway Vehicle" package.
Viperdave is offline   Reply With Quote
Page generated in 0.44252 seconds with 74 queries
