XJ D30 Non-disco - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 11th, 2006, 09:33 AM   #1
quicksilver
quicksilver's Avatar
Default XJ D30 Non-disco
Sold!!!!!!
quicksilver is offline   Reply With Quote
Old February 11th, 2006, 12:01 PM   #2
PavementPounder
PavementPounder's Avatar
I thought they went to non-disco in the last couple years of production?
Old February 11th, 2006, 03:55 PM   #3
quicksilver
Some axles through 91 are vacuum disconnect, 92+ are non-disconnect, 89-95 with ABS have 5-297x u-joints so it might have the bigger ujoint. I didnt look at it that close. Both U-joints will need to be replaced. I started to do it but thought it would be easier on me to just use the axle that is already under the jeep since I dont have to drive it every day anymore.
Old February 11th, 2006, 04:01 PM   #4
Immortal
NO RELIGION WAT!
Immortal's Avatar
BTW.......abs is usually a sign of 297 u-joints. QS you also have another pm
Old February 11th, 2006, 04:13 PM   #5
quicksilver
Thanks Immortal...
I also should add that the uni-hubs are off the axle. I was going to replace the U-joints but only got as far as taking off the hubs. I could put them back on if you wanted but it would be easier to replace the u joints this way. I also have the calipers and rotors from the axle if wanted.
Page generated in 0.24144 seconds with 38 queries
