HP Dana 30 strength - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 29th, 2007, 12:27 PM   #1
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
Default HP Dana 30 strength
How much weaker/stronger is a HP Dana 30's 4.88 R&P compared to a 4.56 R&P? 98 XJ not that it matters what it's in.
Old May 29th, 2007, 09:35 PM   #2
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
Anyone?
Old May 29th, 2007, 09:51 PM   #3
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Well...the HP is stronger...how much stronger?
The easy answer is "a factor of 1.874".
Old May 29th, 2007, 10:12 PM   #4
I basically see 35s as the limit for any Dana 30, and thats still going to see breakage. Even if the ring and pinion were bulletproof, its gonna break everything else.
Old May 29th, 2007, 10:36 PM   #5
Grandman
do i look old !
Grandman's Avatar
I dissagree , i found any thing over 33 " was breaking stock shafts right and left .
Ring and pinion may hold 35" if you run molly shafts .
Old May 30th, 2007, 10:06 AM   #6
silverxj
Recovering XJ owner
silverxj's Avatar
put it this way, the pinion for a d30 4.88 is almost the size of half dollar ... if that. Probably closer to a quarter.
Do you want your r&p as a weak link or a u-joint? D30 shafts are pretty easy to come by- unless you go cromolly.
Old May 30th, 2007, 01:42 PM   #7
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
That is the answer I was looking to find. 4.56's it is for now.
Page generated in 0.17222 seconds with 44 queries
