Jeep Sand Drag Mud Bogger Dune Toy BBC possable part out - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 28th, 2007, 09:44 PM   #1
sandmaster
sandmaster's Avatar
Default Jeep Sand Drag Mud Bogger Dune Toy BBC possable part out
might consider parting this out too .this is just a feeler if it needs to be relocated please do so
Jeep Wrangler Frame and Steel Tub
468 BBC approx 600 hp
steel crank forged rods 11.5 forged pistons
cast gm hp square port heads tripple spring valve springs on ss valves
chromeolly retainers solid cam roller rockers
aluminum radiator with electric water pump and 2300 cfm electric fan
msd pro dist and 6 al ignition and wires
th400 trans with trans brake and coan 5000 stall
electric fuel pump fuel cell
ford 9 inch rear end strange center section with moser spool with 33 spline moser axles with 5.43 gears in rear
front axle is locked with 4.10's
chain drive off rear drive shaft for t case
33-17-15 super scoops with 18 stagered scoops on light weight steel 15x18
1200 -15 desert tracs on 15x10 aluminum wheels in front
full cage tied into frame
5 point harness on both front seats
autometer memory tach and gauges
second fuel pump and pluming if nos is a desire
front clip is a extended full fiberglass raceing front end from power pro racing
the front clip does have a couple crackes but easy fix
custom hooker supercomp headers into 4 in exhaust to flow master mufflers and a 4 inch out to a turn down sounds very sweet
front steering is a rack n pinion on the front axle
front suspention is a three link coil over with avo aluma coil over shocks n springs
rear is a four link coil over setup by chassie enginering
front and rear drive shaft safty loops
asking 10500.00
sandmaster is offline   Reply With Quote
Old May 28th, 2007, 11:24 PM   #2
jeeptjpaul
jeeptjpaul's Avatar
Is that a normal thing to run different gears front and rear in a sand buggy? What are the advantages?
jeeptjpaul is offline   Reply With Quote
Old May 29th, 2007, 09:18 AM   #3
Strangler
Strangler's Avatar
Different tire size front/rear.
Old May 29th, 2007, 05:02 PM   #4
Monster4.0
Monster4.0's Avatar
More front wheelspeed for steering too.
Old May 29th, 2007, 10:51 PM   #5
feelsoright03
feels so right
feelsoright03's Avatar
Send a message via AIM to feelsoright03 Send a message via MSN to feelsoright03
seen this jeep over the weekend in silver lake its a nice rig bump for ya.
~Teddy~
feelsoright03 is offline   Reply With Quote
Old May 30th, 2007, 12:00 AM   #6
jeeptjpaul
jeeptjpaul's Avatar
Duh.. I don't know why I didn't think of that. Thanks.
Old June 6th, 2007, 08:50 PM   #7
sandmaster
sandmaster's Avatar
lower price
Old June 12th, 2007, 11:14 PM   #8
sandmaster
sandmaster's Avatar
ttt
Page generated in 0.25314 seconds with 47 queries
