Blue XJ's Not so Blue MJ Build Thread - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 31st, 2008, 07:57 PM   #41
Blue XJ
The Green Machine
Blue XJ's Avatar
Send a message via AIM to Blue XJ
Originally Posted by dline View Post
cool i'll be looking for it when its on the road.
I've seen your truck around, so I'm sure you'll see it once I start driving it. I'm right off of 19 and Hartwick, I've seen you on 19 a few times.
Blue XJ is offline   Reply With Quote
Old March 31st, 2008, 08:58 PM   #42
dline
dline's Avatar
dline is offline   Reply With Quote
Old March 31st, 2008, 09:54 PM   #43
TJontherox
Mall Rated
TJontherox's Avatar
Send a message via Yahoo to TJontherox
I couldn't quite remember where you lived. I know you told me when you stopped by my house to pick up the ramps. I'll keep an eye out for ya too.
TJontherox is offline   Reply With Quote
Old April 1st, 2008, 04:14 PM   #44
Blue XJ
The Green Machine
Blue XJ's Avatar
I'm about 5 blocks away or so. I'm in the sub on the other side of hte powerlines, more or less at canal and schoenherr
give me a month or so and it'll be on the road.
Old April 1st, 2008, 06:55 PM   #45
arcticjeff
Arcticjeff
arcticjeff's Avatar
Man, love your work. I only hope mine turns out as good. Just need to find one pimp.
arcticjeff is offline   Reply With Quote
Old August 16th, 2009, 08:23 AM   #46
Blue XJ
The Green Machine
Blue XJ's Avatar
Well, its been a while, but its been done for some time now. Been driving it around and took it up to Rocks and Valleys. I decided to feshen up the front end a little too...
ended up having to trim a LOT more
with the new front end...
Old August 16th, 2009, 08:48 AM   #47
mrclean
Silver Lake
mrclean's Avatar
Looks good for a $50 truck
2 things:
1. I don't like you now because you bought the $5 fender that I needed
2. Before I junked my comanche, I pulled the taillights (perfect) and all of the flares and brackets. Let me know if you need those things
mrclean is offline   Reply With Quote
Old August 16th, 2009, 09:48 AM   #48
Blue XJ
The Green Machine
Blue XJ's Avatar
that $5 fender worked good, I trimmed most of the dent out of it too!
I could use a spare set of tail lights, I have an idea to freshen them up a bit, just not sure I want to attempt it on my only set. How much you looking to get for them?
I have no need for the flares, I think I have 2 sets of front and rears, but the front don't fit anymore, theres no metal left to attach them.
Old August 16th, 2009, 01:30 PM   #49
mpsbvp
Hummer recovery team
mpsbvp's Avatar
Send a message via AIM to mpsbvp Send a message via Yahoo to mpsbvp
Looks great
mpsbvp is offline   Reply With Quote
Old August 16th, 2009, 01:49 PM   #50
dline
dline's Avatar
nice congrats on getting it done?
i'll be looking for the comanche tractor, (my buddy had a cherry bomb on his comanche it sounded like a tractor)
Old August 16th, 2009, 05:35 PM   #51
cj7on44's
cj7on44's's Avatar
thats a nice looking xj you had and that mj looks even better
cj7on44's is offline   Reply With Quote
Old August 21st, 2009, 08:41 PM   #52
GrizzlySpitter
In the band!
thats pretty sweet man..your a good rig builder
GrizzlySpitter is offline   Reply With Quote
Old August 21st, 2009, 08:59 PM   #53
89eliminator
cheesehead wheeler
89eliminator's Avatar
why not just soa the rear? worried about axle wrap?
89eliminator is offline   Reply With Quote
Old August 22nd, 2009, 10:21 AM   #54
Blue XJ
The Green Machine
Blue XJ's Avatar
because i didn't have a set of factory springs to use when I got it, and I got these Alcans for a pretty good price. Plus with the stroker motor, and SOA I'm sure there would have been a ton of axle wrap.
Old August 22nd, 2009, 12:19 PM   #55
silverxj
Recovering XJ owner
silverxj's Avatar
nice..
Old August 22nd, 2009, 12:24 PM   #56
89eliminator
cheesehead wheeler
haha, most likely. i get minimal wrap with mine but thats with a Renix, 4.10s, and a detroit.
Old August 22nd, 2009, 02:20 PM   #57
ddeadserious
ddeadserious's Avatar
Looks awesome man, good work.
ddeadserious is offline   Reply With Quote
Old December 13th, 2009, 12:07 PM   #58
Blue XJ
The Green Machine
Blue XJ's Avatar
Got a little more work done on this. I picked up a bender a few months ago and have been slowly building additional cage pieces for it. The yellow is the D&C XJ Cage, stuff not yellow is stuff I have added.
Added door bars and a couple overhead bars to build an overhead console from
Seat belt bar
Not a bad notch for doing it by hand with a grinder, this is about how all of them look. Now only if my welds turned out just as good.
I also picked up a bed mounted toolbox at Lowes for a killer price
Bent up a b-hoop to match the contour of the cab
added some down bars
The rear portion is tied into my rock rails and rear wheel wells, both of which will get some tube for reinforcement over the holiday break.
Also built a track bar brace to help stiffen up the front end. Actually made a noticeable difference
Old December 13th, 2009, 12:11 PM   #59
Blue XJ
The Green Machine
Blue XJ's Avatar
I picked up a set of doors from a 99 XJ, along with the shifters and center console. I painted the doors this weekend, but I'll probably wait till the week after Christmas to install them. I did however get the console and newer shifters in
I'm going to try to dye the dash gray to make it match.
I spent a few hours in the garage with the FSM and figured out the wiring. You have to create a relay circuit that reverses polarity. I will sketch up what I did and post it later, but here is the wiring. I'll made it a nicer schematic later, but for now, here's the connections.
In order to get it to work properly, I had to cut the pink/black and orange/black wires on the passenger door that ran from the lock motor to the passenger switch. Its pin 1 and 5 in the large connector. If you don't cut these two wires, it will pop a fuse every time the door lock is tried.
And for the relay, here is the pin out, I'll make a diagram when I get time.
Any other wires in the doors were not used. The drivers door has extra wires for the rear door windows. And the passenger door has extra wires for the remote keyless entry (RKE) module that I did not use.
Old December 13th, 2009, 12:23 PM   #60
Blue XJ
The Green Machine
Blue XJ's Avatar
I found these mounting panels for ARB switches, so I will pick up a couple to build a panel for my ARB switch and my in cab winch control switches. The panels just snap together to make them as wide as you need.
Page generated in 0.50757 seconds with 83 queries
