Blue XJ's Not so Blue MJ Build Thread - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 29th, 2008, 02:09 PM   #21
Quagmire
I can has layinframe
Send a message via Yahoo to Quagmire
Originally Posted by silverxj View Post
I've noticed you're selling your 32"s ... what's next?
He built an MJ
Google first.....ask questions later
Actually, the new rule of thumb is you should make your tires bulge slightly more then skooterbuilt when he's wearing his tight ladies pants
Quagmire is offline   Reply With Quote
Old March 29th, 2008, 05:05 PM   #22
xj4life
xj4life's Avatar
not to hijack or steal Jeff's thunder but i've got plans to take over what's left of his XJ (just a shell right now) and start a project that will take it to something like this. only smaller tires and a much better exo
Old March 30th, 2008, 10:50 AM   #23
Blue XJ
The Green Machine
Blue XJ's Avatar
Send a message via AIM to Blue XJ
I picked up this for the next "upgrade"
I used 99% of the parts from the XJ to build it. I had to get a gas tank, rear leafs, and a few odds and ends, but everything else is from the XJ.
I'm selling the 32's because I picked up some 35's to put on it.
Blue XJ is offline   Reply With Quote
Old March 30th, 2008, 11:03 AM   #24
Blue XJ
The Green Machine
Blue XJ's Avatar
I started the build with this..... most parts swapped over just fine.
I tore the interior out of the XJ...
And installed it into the MJ. The seats do not swap, so I had to make adapters to get them to bolt in. I also raised them up a little to help with visibility....
Took the front end of the XJ off to make it easier to get the motor out, and to swap everything to the MJ...
The MJ....
The leaky stroker on the way out of the XJ...
And installed in its new home..
Made new control arm mounts to push the axle forward from where it used to be by about 2". Looks pretty good to me.
Didn'e have the steering hooked up and couldn't find anyone to help me line up the body to get the track bar in, so I came up with my own helper...
just a couple more pics
and even picked up a tail gate in good shape.
I got the gas tank mounted, all new fuel lines ran, all new brake lines bent up, new flex lines installed and the brakes bled. The pedal feels a lot firmer than it did in the XJ. I have driven it around the backyard a bit, everything feels good so far.
I picked up a set of 35" bfg's from Craigslist, got them mounted to see how they will fit...
Tire coverage looks to be about perfect with the 35's too. You can even see the poor old XJ in the garage in this one.
I noticed some cracking in between the lugs on the tires, so I decided to get some different ones. I picked up some 35" trxus mud terrains and got those mounted up. Turns out they were once owned by Killer B
Here's how it sits as of last night. Still need to weld the rear axle perches on and finish welded my frame stiffeners on and it will be more or less done.
Old March 30th, 2008, 11:14 AM   #25
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
Awesome Jeff... Also if you got those mud trux's from kaiser42 those were the ones in the basement that I got from CC.
Old March 30th, 2008, 11:15 AM   #26
Blue XJ
The Green Machine
Blue XJ's Avatar
yup, thats them.
They were a bitch to dismount off of those rims too. But they went on my rims super easy
Old March 30th, 2008, 11:17 AM   #27
clarkstoncracker
lol
clarkstoncracker's Avatar
Originally Posted by Blue XJ View Post
yup, thats them.
I loved those tires!
MJ looks nice!
Old March 30th, 2008, 06:36 PM   #28
LAWNMAN323
MOWUOVR
LAWNMAN323's Avatar
Nice job.
For all that trouble, I hope you don't bash that longbox on trees and take it off and tube it out, you could have just kept the XJ.
Nice job though, I'm impressed.
LAWNMAN323 is offline   Reply With Quote
Old March 30th, 2008, 06:43 PM   #29
nate4d
Gnarley Davidson
nate4d's Avatar
Send a message via AIM to nate4d
looks good. gonna shorten the bed?
nate4d is offline   Reply With Quote
Old March 30th, 2008, 07:16 PM   #30
zanderman90
MTU here I come.
zanderman90's Avatar
Nice MJ. Are you going bob the bed, make a tube bed, or just leave it the way it is.
zanderman90 is offline   Reply With Quote
Old March 30th, 2008, 10:26 PM   #31
Blue XJ
The Green Machine
Blue XJ's Avatar
the plan is to bob and dovetail the bed, but not for a while. I'm gonna wheel it how it is, but I'll add some bed rail sliders to it when I weld the cage in.
Old March 30th, 2008, 10:55 PM   #32
88mudder
In the band!
nice build
Old March 31st, 2008, 12:46 AM   #33
ddeadserious
ddeadserious's Avatar
Nice build for real, so does it move under its own power now?
ddeadserious is offline   Reply With Quote
Old March 31st, 2008, 12:57 AM   #34
Mclovin
"The Situation"
Mclovin's Avatar
def bob that bed man, if you dont you'll be wishing you did everytime u come off an edge. I'd open the rear wheel well up a bit too. but thats just me.. you're doing a nice job !
Old March 31st, 2008, 05:30 PM   #35
Blue XJ
The Green Machine
Blue XJ's Avatar
It runs and drives under its own power. The only thing from keeping me off the street is the rear spring perches aren't welded on yet. I just have them resting there with the ubolts loosely holding it all in place.
I'll bob it eventually. The rear quarters on my XJ were all smashed up, and they were like 2 feet shorter than these. The plan is to make a custom rear bumper/crossmember and the spring shackle will be mounted to the rear face of it. Then trim the bed so its all flush is the rear.
Old March 31st, 2008, 05:35 PM   #36
mrclean
Silver Lake
mrclean's Avatar
Looks like Poop
I would say it's worth about $50 :tonka:
looks good jeff
mrclean is offline   Reply With Quote
Old March 31st, 2008, 05:44 PM   #37
Silver Bullet
Livin the American Dream
Silver Bullet's Avatar
what was the reason for dumping the xj for the mj
Silver Bullet is offline   Reply With Quote
Old March 31st, 2008, 05:50 PM   #38
Blue XJ
The Green Machine
Blue XJ's Avatar
I have had the XJ for 9 years, time for something new, and it was getting prety rusty in some key areas. Like the front leaf mounts were pretty weak, the frame where my 3 link attaches was getting tweaked after every trip out.....
And I've always liked MJ's
Old March 31st, 2008, 06:32 PM   #39
dline
dline's Avatar
cool i'll be looking for it when its on the road.
dline is offline   Reply With Quote
Old March 31st, 2008, 08:31 PM   #40
Silver Bullet
nice ya dont see many of em.
Page generated in 0.42042 seconds with 83 queries
