can i put my stock spiders (4.11) back in with 4.56 gears? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 26th, 2007, 10:40 PM   #1
luvitmyjeep
broken
luvitmyjeep's Avatar
Default can i put my stock spiders (4.11) back in with 4.56 gears?
i broke my locker last weekend and someone said i could only put the stock spiders in if they were 3.07 or lower. i baught the axels with the lockers already in them and he gave my the stock spiders but i dont know if he had changed the carrier.
the axel is a d30 and the gears are 4.56s the locker was a power traxx no slip
thanks aron
luvitmyjeep is offline   Reply With Quote
Old May 27th, 2007, 12:35 AM   #2
Sandals
Fucking Zen as Shit
Sandals's Avatar
I believe you can
IIRC D30 spiders are D30 spiders, only thing he ratio should affect is the carrier itself.
Old May 27th, 2007, 12:45 AM   #3
Cooter
Dad Kickin' It OldSkool
Cooter's Avatar
Actually, I said you could you replace the spiders without pulling the ring gear only if you had 3.07s in your D30 (maybe if you had 3.54s, as well- I'm too lazy to try to look it up)
Your spiders will work with any gear ratio, as long as you swap them into a stock, open carrier. (They can't be swapped into a ARB without some fab work) :tonka:
Old May 27th, 2007, 08:02 AM   #4
luvitmyjeep
broken
thanks cooter you have been a huge help i owe you a or 12!
Page generated in 0.21953 seconds with 35 queries
