Project Horse Play***It Lives*** - Page 9 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 5th, 2009, 05:08 AM   #161
Rayden21
Hell Yeah It's Fast
Rayden21's Avatar
Looks fantastic. I always wanted one of these. Great fabrication work.
Rayden21 is offline   Reply With Quote
Old January 5th, 2009, 07:00 AM   #162
Miffy
Miffy's Avatar
Send a message via Yahoo to Miffy
would you hurry up!
Nice work Ken, can't wait to see it on the trails.
Miffy is offline   Reply With Quote
Old February 9th, 2009, 09:28 PM   #163
bronco4-play
Do it like you mean it
bronco4-play's Avatar
The rear disc brakes turned into a fiasco. To make a long story short, I bought a bolt on bracket kit off ebay and after some miscomunication the final product was not what I was looking for, so I modified it to fit my needs. I extended the brackets to fit a larger rotor and beefed up the thin area around the center bolt hole.
The final product uses a stock 1/2 ton 9" axle shaft. Scout rotors that have been re-drilled, cleaned up on the back to fit over the axle flange and turned down .050" to fit the GM metric calipers. I found some lug studs that fit the stock axles and have an extended shoulder for the rotor to center on. And a cheap set of pads from Autozone because they are thinner and will let the caliper fit the thick rotor.
After the month long goat rodeo with the brakes was finally over I turned to the steering shaft. I put the shaft out of the old 4-PLAY rig up there to see how much it needed modified and it was a perfect fit with no mods needed! The angle looks a little steep but only it measures 32 degrees.
I had hoped to use the stock EB instrument cluster but it will not fit in this dash. Time to play cardboard-mock-up to get the aftermarket stuff to fit.
bronco4-play is offline   Reply With Quote
Old February 12th, 2009, 10:20 AM   #164
KennyOffroad
Ridge Runners Offroad
KennyOffroad's Avatar
Nice !
Old February 15th, 2009, 02:52 PM   #165
Broncoholic
Guest
Posts: n/a
Swweet rig man See ya at SL spring time. PM me on the specrs for your radius arms Look like a nice fit for my 71.
LONG LIVE EB's
Old March 29th, 2009, 11:42 PM   #166
bronco4-play
The dash is done and waiting for wiring before I install it
Got the new winch. The bumpers are being bent up by the same guy that did the dash.
The front calipers have a 7/16-20 banjo bolt and the only DOT braided lines I found are 10mm, so I built this smoothie adapter.
Shot a coat of white on the gate and added a little bling (it actually covers a bunch of holes from rivits etc.).
Old March 30th, 2009, 11:02 AM   #167
Old March 30th, 2009, 05:43 PM   #168
firehawk
Live Action!
firehawk's Avatar
Very nice.
I am looking forward to seeing the new bumpers!
Old April 19th, 2009, 08:06 PM   #169
bronco4-play
It hit the scales with no top, doors, bumpers, or fluids. When it hits the trail it will be about 5k including gear and people. I was hoping for less but that's still 1500 less than 4-play was trail ready.
She stands on all fours for the first time (with the mock shocks), the coilovers are ordered and on their way.
Got a universal 18 circuit wire harness from Summit. Tried to follow the instructions but it was set up for GM switches and there's circuits in the harness that are not in the instructions. Threw the directions away, cut the plugs off and here we go.
Not sure if I'll make it but I'm trying to make it start and run long enough to get on the trailer, so I can take it to Broncorama at Jeffs in 2 weeks.
Old April 19th, 2009, 08:39 PM   #170
Woodyjiw
FUCK CANCER!!!
Woodyjiw's Avatar
Sweat build!!
Woodyjiw is offline   Reply With Quote
Old April 20th, 2009, 12:00 AM   #171
Broncoholic
Guest
Posts: n/a
See ya @ Jeffs
Should have got a Centec Harness
Old April 21st, 2009, 08:37 PM   #172
bronco4-play
Originally Posted by Broncoholic View Post
See ya @ Jeffs
Yup, and I would have if I had checked into them. I read so much complaining about their harness that I never checked their website. The new painless harness for the EB looks to be the cats ass for more of a stock configuration. But I have shuffled everything around and used enough non-factory parts that it wasn't worth the $800+. The Summit universal harness I got has a covered fuse panel and 18 circuits with all the wires labeled, and it was only $200. I was able to find the wire ends that snap into the light and wiper switch plugs. But I used the Ignition switch from the 79 and couldn't find those wire ends, so I had to splice that and the column plug also.
Old April 21st, 2009, 09:50 PM   #173
stinkpickle
bitter clinger
stinkpickle's Avatar
beautiful.
stinkpickle is offline   Reply With Quote
Old May 1st, 2009, 11:14 PM   #174
bronco4-play
Default It Lives !!!
Not done yet but fired, running and put 5 miles on it tonight. It's on the trailer now and will be at Bronco-Rama in the morning.
Thanks to several good friends help, late into the night for the last couple weeks.
Pics later.
Old May 1st, 2009, 11:16 PM   #175
xj97sport
atv rider
xj97sport's Avatar
1. isnt it past ur bed time?
2. when will i see this in action ... let go wheelin next weekend ... a lil test and tune WOOT
Old May 3rd, 2009, 12:21 PM   #176
bronco4-play
Got the shocks on Thursday night and it stood on it's own legs.
It started and ran for 5 minutes and the MSD box pooped out. So we cobbed my dura-spark II trail spare on it to get it going.
At last it moves under it's own power. I put 5 miles on it up and down the road with no mufflers and the cops didn't even show up. Either my PITA neighbor is mellowing or the cops are tired of them calling.
Made it to the Broncorama show at Jeffs. The most frequently asked question of the day, "is that a 460 in there"?
Old May 3rd, 2009, 12:25 PM   #177
Ford forever
Bought another jeep
Sweet you puttin the front clip on?
Ford forever is offline   Reply With Quote
Old May 3rd, 2009, 12:39 PM   #178
bronco4-play
Yes, I just pulled it at Broncorama to show off a little.
And it worked.
Old May 3rd, 2009, 02:54 PM   #179
Broncoholic
Guest
Posts: n/a
Default Nicer in person
Hey that is sweet I was the guy in the Cat Racing coat & hat, Checkin the axles. & front cage. I will put you on my list. I had the 76 Sport with the CLEVOR in it across the street. In my Gallery.
Sweet lookin in person I will have to take some notes on that thing.
Old May 3rd, 2009, 07:08 PM   #180
Tacker
Tacker's Avatar
Looks Great! Sweet Build .
Page generated in 0.43184 seconds with 84 queries
