Project Horse Play***It Lives*** - Page 8 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 8th, 2008, 07:00 PM   #141
bronco4-play
Do it like you mean it
bronco4-play's Avatar
22# of wire and one tank of gas, the frame and nerf bars fully welded with gussets on all the mounting points and fish plates over the joints in the rails. The storm knocked the power out before I got to the cage.
bronco4-play is offline   Reply With Quote
Old June 9th, 2008, 06:16 AM   #142
91 k1500
Big Belly Customs
91 k1500's Avatar
Send a message via AIM to 91 k1500
very nice fab work!!!! hope to see this thing up at silver lake in the future.
91 k1500 is offline   Reply With Quote
Old June 9th, 2008, 08:01 PM   #143
holshotracer
Its not mine
holshotracer's Avatar
Sounds like you did a little bit of welding
holshotracer is offline   Reply With Quote
Old June 9th, 2008, 08:36 PM   #144
merr6267
More boost than yours:)
merr6267's Avatar
I just saw this thread for the first time . . . nice work.
I can't wait to see the final result.
merr6267 is offline   Reply With Quote
Old June 15th, 2008, 09:20 PM   #145
bronco4-play
Bolted the cage back on to finish welding it.
Put gussets in all the tube joints and bolted a piece of 1/4" aluminum plate in the top to hang the CB and such from.
Old June 15th, 2008, 09:41 PM   #146
jeeperbrian
GLFWDA member
this truck is goin to be bad ass, great work
Old June 18th, 2008, 10:29 AM   #147
KennyOffroad
Ridge Runners Offroad
KennyOffroad's Avatar
:dunie:
Old June 18th, 2008, 10:39 AM   #148
liv2mx
i like jungle gym's.
liv2mx's Avatar
skills. looks great.
Old June 18th, 2008, 03:47 PM   #149
Tikiclub2
Sweetness!
Tikiclub2 is offline   Reply With Quote
Old August 17th, 2008, 07:56 PM   #150
bronco4-play
Chassis has now been sandblasted, coated with self etching primer inside and out, and painted gloss black.
Welded the caps on the rear of the frame rails after the paint inside dried. Did it this way because I was concerned the paint would not cure properly without some air circulation.
Old August 17th, 2008, 07:58 PM   #151
Originally Posted by Tikiclub2 View Post
Sweetness!
Old August 17th, 2008, 08:07 PM   #152
frdtrckmnrich
FORD The Best Never Rest
frdtrckmnrich's Avatar
Lookin Good!!!!!!!
Old August 17th, 2008, 09:11 PM   #153
roll-bar Bob
roll-bar Bob's Avatar
Old August 18th, 2008, 12:01 AM   #154
sandman86
sandman86's Avatar
SO F-ING SWEET DUDE! nice build
sandman86 is offline   Reply With Quote
Old January 4th, 2009, 08:39 PM   #155
bronco4-play
Ok time for an update.
Reshaped the tunnel and made a removable aluminum cover to lower it 2". This makes for better shifter boot fit.
Opened up the notch in the firewall to fit the motor and fabed another aluminum cover.
Put new frictions and seals in the tranny along with a reverse pattern manual valve body. It already had the wide ratio platetaries and torrington bearings. The 205 was overhauled and twinsticked just before I retired the big Bronco.
Rear end is in with the 456's and detriot from the big Bronco. Waiting for the big brown truck to bring my rear disc brackets before I install the axles. I was going to use the rear disc setup off the 77 lincoln, but the distance between the housing and the axle flange is off by 1/4" and the inner pads would fall out when they are about half worn out.
My helper has gotten a lot of experience with a wire brush, scotch brite pad and a rattle can.
The motor got a new set of bearings, water pump and a rattle can overhaul. Also have a truck avenger carb I'm going to try out.
Been thinking about scrapping the on board air compressor and putting a weldernator in it's place. I've got an ultimate air set up for my tires now.
Old January 4th, 2009, 08:43 PM   #156
Bronco351
Powered by Ford
Bronco351's Avatar
Send a message via Yahoo to Bronco351
sweet
Bronco351 is offline   Reply With Quote
Old January 4th, 2009, 08:44 PM   #157
1badzuk
1badzuk's Avatar
wow wow damn that is coool
1badzuk is offline   Reply With Quote
Old January 4th, 2009, 08:45 PM   #158
i was starting to wonder.....
Old January 4th, 2009, 08:48 PM   #159
Fullsize4life
Kicking Cancers ASS
Fullsize4life's Avatar
Old January 4th, 2009, 09:03 PM   #160
holshotracer
Its not mine
You doing a hell of a job on it.
Page generated in 0.35430 seconds with 84 queries
